  • Guests: 37
davovinch (75)
Duncan (37)
Vatorius (60)
waicool20 (27)
12/11 Forty (38)
12/13 williamn (48)
12/13 ReddyK (57)
Electrets
IntraWinding
Tue Jun 29 2010, 10:11PM Print
I've always fancied having a go at making strong Electrets, the electrostatic equivalent of magnets.
I'd like strong monopoles and dipoles I can handle so I can get a sense of how they differ from the familiar effects of magnets. Presumably it's hard to make them that strong or we'd see them more often.
ShawnLG
Wed Jun 30 2010, 08:58PM
How do you make electrets?
Pinky's Brain
Wed Jun 30 2010, 09:59PM
Charge metal powder in a container (so it doesn't fly off everywhere) and then put in liquid paraffin, mix with one of those magnetic beads until it solidifies?
Kilham
Wed Jun 30 2010, 10:15PM
Kilham Registered Member #2814 Joined: Wed Apr 21 2010, 12:28PM
Heating and cooling a piece of plastic whilst in an electrostatic field. I tried this about 25 years ago with some limited success, it's difficult to make it last any length of time though.
IntraWinding
Wed Jun 30 2010, 11:52PM
The classic electret is made by cooling a mixture of melted waxes in a high voltage field. It solidifies with polar molecules aligned. As I understand it that gives you a dipole electret in that one side will be +ive and the other -ive, in the same way magnets have a north and south pole.
Unlike magnets though, you can make monopoles. The sort of thing I've imagined is a ball bearing encased in PTFE. You could charge the ball bearing to a high negative potential with an electron accelerator and hopefully the charge would remain trapped. More easily I can imagine placing a rounded metal shape in a liquid plastic and before it sets, dipping in a wire and charging it to a high voltage.
Here's the old Amateur Scientist article Link2
Here's something I hadn't considered. The way magnets and electrets interact is unusual:
"If you take one electret and one magnet you will get a surprise. When not in motion, these two differing objects will have no effect on one another. It is only when you move them that anything happens ... and ... it is not the familiar attraction-repulsion. When a pole of the magnet is in relative motion to a "pole" of the electret they push each other at 90 degrees to the direction of motion. The effect is entirely odd and immediately unfamiliar (unless you are a physics student)."
Thu Jul 01 2010, 02:02AM
Sounds like an interesting endeavor. You found the Amateur Scientist column; here's another DIY reference. Link2 [edit]Please note that that reference shares a domain with everything from worm composting to free energy machines.
What properties are you going to measure to confirm that the finished product is an electret? Planning to make a teslatika? smile
I think electrets are present in the majority of the world's microphones today, when we count the ones in telephones, headsets, etc. Link2
Does a statically charged object embedded in insulator count as an electret? Then "many" (a significant understatement) are found in nonvolatile semiconductor memories! I thought the term means an insulating material that retains electric polarization in the absence of an applied electric field.
radiotech
Thu Jul 01 2010, 04:07AM
The electrets used in microphones would have a model that would equal a insulator that gave evidence of a charge difference when a means to cause the oppositely charged faces to acquire the same charge. However whatever electrical energy is obtained by conducting from face to face is derived by the work (in the case of the microphone) of moving the diaphram. In other words it is as useless as a magnet for storing energy
Old capacitors sometimes show microphonics in amplifiers if you tap them gently.
This reflecting galvanometer works when probing very weak currents.when the reflected light beam is 10 M long, and nothing is vibrating the floor, it works great. We've used it to prove the current from a 12 inch electrophoresis disk can to a bit of work.
Leeds and Northrup--sensitivity 0.0041 uA/MM
1277957273 2463 FT91671 Reflectinggalvo
1277957273 2463 FT91671 Galve Specs
IntraWinding
Thu Jul 01 2010, 05:20PM
Klugesmith wrote ...
Looking at the Wiki Article on electrets, I think perhaps an my insulated metal monopole idea doesn't count as one. It looks like the charge is supposed to be distributed within or on the surface of a dielectric. It would still be an interesting artifact to create though. Link2
I'm not planning to make electrets yet - I'm interested to know if it's possible to make them strong enough to handle and experience strong attraction/repulsion forces in the same way you can with magnets (see original post). And now I'm also interested to see how they interact with magnets. It looks like PTFE is the stuff to use, which is handy as it's easy to get hold of on eBay these days.
Thu Jul 01 2010, 06:37PM
IntraWinding wrote ...
There's a reason most practical motors are electromagnetic rather than electrostatic.
At reasonable magnetic flux density of 1 Tesla, the attraction between two pole faces in air is 400 kPa (4 bar or about 60 psi).
At an electric field strength of 3 MV/m (threshold of breakdown) in air, the attraction between two parallel plates is just 40 Pa (0.4 mbar or 0.16 inches of water column), in my unreviewed calculation.
In both cases, the forces are proportional to the square of the field strengths.
In dielectric oil at an aggressive E-field of 15 MV/m, we're up to 3 kPa (0.4 psi), still more than 130 times weaker than the magnet system.
Anybody got engineering data on the strength of commercial electrets, such as microphone film?
-Rich
Mon Jul 05 2010, 12:01AM
That was a very interesting article, and it seems that if it were possible to get 40pa it would be easy to observe the effect (40pa over a 1in^2 area is about 2g of force).
I found the comment that the charge falls to 0 and then reverses to be the most interesting, the time scale of a few weeks seems to rule out any possible explanations I can think of. Who is up to build one and connect it to a high impedance voltmeter and observe the process cheesey
