  • Guests: 51
10/21 ben106 (40)
10/22 803 (2025)
10/23 Iniaes (17)
CRT monitor oscilloscope
haxor5354
Sat Jun 26 2010, 11:13PM Print
I turned a computer CRT monitor into a simple oscilloscope for music visualization.
all i did was disconnect the horozontal deflection coil from the circuit board and connect it to a music source
link for instructons ---> Link2
i just made 1 today and it worked until i turn the monitor off, when i turn it back on it only automatically shuts off.
then i connect the horozontal deflection coil back to the circuit board, it displays the no-input screen normally. and i disconnected it from the circuit bord and connect it back to the sound amplifier, it works again cry
could it be the monitor's protection tht automatically shuts it off? do i need to add a dummy coil to the circuit board?
3l3ctrici7y
Sun Jun 27 2010, 09:05AM
3l3ctrici7y Registered Member #1806 Joined: Sun Nov 09 2008, 04:58AM
From what you describe, it sounds like some sort of POST (power on self test). I don't see this as a big deal. Making a coil might work, but I wouldn't know how to go about that. From what you say, I think the simplest solution would be to throw a DPDT switch in there. Crude, sure; effective, yes. If you wanted to go whole hog, you could add a relay with an RC time delay so that it will switch the wires over after a certain length of time after power on.
radiotech
Sun Jun 27 2010, 03:13PM
Find another similar monitor and remove the yoke assembly. Use that yoke H def coils as your dummy coil. Mount it inside the monitor you are using for scope-like display.
