  • Guests: 40
williamn (48)
ReddyK (57)
Birdman (31)
12/14 M.A.D. (32)
12/15 marko666 (58)
12/16 Will T (16)
Wiring MOT's ..
lpfthings
Thu Jun 17 2010, 07:08AM Print
lpfthings Registered Member #1361 Joined: Thu Feb 28 2008, 10:57AM
Hi, I am building a power supply for an argon laser. The laser requires about 100VAC @ 10A. Since I live in AU, my wall voltage is 240V, which means I need some sort of stepdown transformer. Being transformers, they are naturally heavy, so buying one rated for that kind of power is proving to be expensive. So I was thinking, is it possible to get 50VAC from 1 MOT, and have 2 in series for 100VAC? This would then be rectified into a big filter cap, and into a linear passbank. Ideally a SMPS would be much better, but finding one that would handle that power likely wouldn't come cheap :(
Or, any other ways to get that kind of voltage from 240V mains?
Cheers,
Dan
