  • Guests: 42
Audio modulated LOPT/FB
Tigeris
Wed Jun 16 2010, 09:19PM Print
Tigeris Registered Member #1656 Joined: Wed Aug 27 2008, 03:28PM
Dumb question, but one I couldn't find a definite answer on. I am working on another audio modulated flyback, and the mosfet used is an IRFP250N. My question is, could i use an IRFP450 instead?
1
hboy007
Wed Jun 16 2010, 09:56PM
It looks like the circuit relies on a slowed-down turn-off of the mosfet. A more reasonable approach would be to add a capacitor across the source and drain tabs to control the inductive peak. You might end up killing mosfets with low gate capacity with this ciruit. Once you have the (drain!) voltage swing under control, almost any mosfet you can drive with the oscillator output will do. The IRFP450 may be a suitable replacement but look over the schematic before actually building it. Even TVS diodes / VDRs / RC-Snubbers won't hurt. I suggest you add a 400V TVS diode to the IRFP450 as an olfactory overvoltage sensor wink
radiotech
Thu Jun 17 2010, 03:20AM
" audio modulated flyback- "
Why not modulate the flyback like this?-- wrap 3 turns around the core one way and another 3 on the otherside in series opposing. Connect these to the speakler terminals of an audio amp with a 0.01 uf cap in parallel,
This is an old technique known as an increductor. It was used to modulate an oscillating ferrite core and worked very well with 60 Hz
modulating. Perchance it will cause mixing (modulation) of the drive rate with the audio.
Tigeris
Thu Jun 17 2010, 03:51AM
radiotech wrote ...
Wow, crazy, i never heard of that before. Do you have a link or diagram by chance?
Ok. the IRFP450 worked as far as turning it on, But i still get o audio. Everything is to spec to the diagram. *is getting a headache*
[Edit: Double post]
