  • Guests: 50
Ballast questions
Adam Munich
Tue Jun 15 2010, 10:29PM Print
Okay, so i want to push my XRT to the max. However, it seems i need a ballast. Just plugging it into the wall produces impressive results, and the XRT seems to be able to handle it, however it blows my breaker in 5 sec ;).
What are some good ballast ideas. Don't say salt water resistor. Not going to happen.
Tue Jun 15 2010, 10:42PM
Even "nominal" voltage is likely to soon destroy your precious XRT by internal arcing,
even if it's dunked in oil, unless the immersion is done properly with heat and vacuum.
If your real interest is x-rays, skip the arcs and sparks completely,
and put some miles on your system at never more than half voltage.
See threads Link2 and Link2
Adam Munich
Tue Jun 15 2010, 11:23PM
Nah, it's under oil pretty good. Spent hours massaging all the bubbles out. So far i haven't had any trouble, even running it as an induction coil getting 8" sparks out.
Besides, i have no money to make a tesla coil.
Wolfram
Tue Jun 15 2010, 11:41PM
Didn't you have a variac on the way?
I think you are running the transformer on the edge of saturation, cut the input voltage down just a bit, maybe to 100V, and the current draw should go down to probably under 0.1A with no load on the secondary.
Anders M.
Adam Munich
Tue Jun 15 2010, 11:44PM
Anders M. wrote ...
Anders M.
I think it was too. Anyway, i just rigged up a 55 ohm resistor bank and it seems to work fine. I'll have to try it at 25 ohms some time. I don't dare go lower than that.
In the video attached it draws 1A.
]xformer.avi[/file]
Wolfram
Tue Jun 15 2010, 11:56PM
Klugesmith wrote ...
I am not surprised the guy in the first link killed his transformer. From one of his posts:
I currently have C attached to core/frame ground
Terminal C in the picture here Link2 is the outer connection of one half of the secondary. He basically shorted half of the secondary, or even worse, if it's the half of the secondary with the floating inner connection for current measurement, half of the output voltage would appear between the inner windings of one secondary and the core.
Grenadier, how large is the gap it's arcing across?
Anders M.
Adam Munich
Tue Jun 15 2010, 11:58PM
Any ideas what i could use this for? I was thinking a massive lifter could be made if i full wave rectify this thing.
radiotech
Wed Jun 16 2010, 09:42PM
Housebreakers are expensive and only have so many fast trips.
Consider these fuses--pennies in flea markets and will blow faster than the lag trip of breaker. they come in 30-25-20-15 and 10-6 -3 however the last three are harder to find.
1276724532 2463 FT91208 Fuseplugs
