  • Guests: 44
Help on MOSFET before I go MAD!!!!!!!!!!!
JamesH
Tue Jun 15 2010, 04:45PM Print
JamesH Registered Member #579 Joined: Mon Mar 12 2007, 09:45AM
I have a problem with MOSFETS
I am building a singing arc with afly back - I have had one going or two working but mainly the MOSFETSget hot and fail after a few minutes
BUT here is what I can not understand :
I have Mosfets in a TO220 package , looking at them with the tab away from me I make it Gate Drain Source left to right = signal , V+ V-
Ihave new Mosfets and used different types Irf 250 , Irf 530 etc all N chanel
I have discharged the Gate and with my finger before soldering the SAME types in parallel But when I attach my 12 v battery to the drain and source leads - with a wound primary coil in series The leads are sshowing a current flow immediately EVEn if I disconnect / have not connected te gate
What am I doing wrong - surely if ther is no signal / voltageon teh gate no current should flow via D- S - Plase help I have mad up five or six circuits now over several das and it is driving me bonkers
To clarify : I see the Mosfet lega being just the same position as a N P N transistor - Left = base . middle = colector, right emmittor and the Mosfet is the same left gate = signal middle leg Drain = Posative right source = to ground -chanel Tr.. Have I gotb this right ?
Why are my MOsfets conducting with no signal to the ate ???
Avalanche
Tue Jun 15 2010, 05:13PM
Stick a pulldown resistor between the gate and source to hold the gate off if no proper driver is connected, something like 1k. That will stop you going mad!
The gate is such high impedance it will 'float' on quite easily, or get 'jolted' on (by parasitic capacitances within the mosfet) just by connecting the circuit up.
Tue Jun 15 2010, 10:25PM
JamesH wrote ...
... Why are my MOsfets conducting with no signal to the ate ???
They are hungry. smile
Avalanche beat me to give the answer.
This is a lesson every digital experimenter learns early (I figured it out age of about 12).
"Not connected" does not necessarily mean Logic 0, or OFF.
In most bipolar logic devices, open inputs are logic High, but not robustly so.
For FET inputs, "not connected" means Voltage Defined by Leakage and Recent History.
(the picture changes if you connect a voltmeter or oscilloscope to the gate).
See if you can touch the gate input with your finger, and get intermediate amount of drain current
as your MOSFET switches at mains frequency. Done carelessly, that experiment can abuse
the device under test, by electrostatic discharge.
[edit] Maybe you do have the pin assignments wrong -- there's no universal standard.
If any pin is electrically connected to the thermal tab, it's probably the drain terminal.
Can you measure the drain-source clamp diode between any two pins?
If you have a DMM with a diode-test range, it will require six measurements, in each case
with the unused terminal tied to the negative probe (assuming you know it's N-channel device).
teravolt
Wed Jun 16 2010, 02:27AM
hi James, do you have a picture of your setup and or a link to the schematic and are you using heat syncs
