  • Guests: 26
  • Most ever online: 596
    Guests: 596, Members: 0 on 25 Oct : 21:25
WaveRider (62)
Njubster (34)
10/30 Aragorn (41)
10/31 Tor (40)
10/31 RussT (67)
Cheep 1W 445nm laser diodes!
FireBird
Tue Jun 15 2010, 05:01AM Print
FireBird Registered Member #1104 Joined: Tue Nov 06 2007, 07:38PM
Well this may be old news to some but I figured I would post this incase someone hasn't seen it. Thanks to Casio's Green Slim Projectors we now have a cheep source of 1W 445nm blue diodes. Basically the projector uses a blue diode along with a phosphor in order to produce green and a high powered red led. I found some information about the diodes on this website Link2
5.6mm closed can laser diode
case neutral
forward voltage of 4.0-4.5 volts
Original output power in projector: >600mW
Forward voltage: 4.0v @ 300mA
Threshold current: 200-300mA
Beam collimates to a 0.75mm x 4.5mm beam at aperture using Aixiz acrylic lens
I also found some diodes on ebay for about $100 and WL is selling this in assembled 1W pointer form Link2
Seems like a good time to start that RGB scanner project I have been holding off on smile
Tue Jun 15 2010, 07:03PM
If anyone needs these diodes, I have them for sale Link2
They are amazing!
IntraWinding
Tue Jun 15 2010, 08:17PM
Thanks for the heads up.
I'd like to understand how the 24 445nm diodes in each Casio projector are used, optically.
As a price guide, bear in mind if buying that this not for profit forum group buy
was charging £38 (US$56 today) per diode + AR coated lens Link2
Unfortunately they don't seem to be selling them any more.
Killa-X
Tue Jun 15 2010, 11:00PM
I own one, very cool :) The projectors run them around 600mA, and thers a lot of people running these at 1Amp...I've seen 1A runs for 40 mins on TEC systems. I, like most others, run them at 700mA I got mine for $50 after shipping, and recently $30
Same diodes are in these, I hope to get mine within 1-2 weeks!
IntraWinding
Tue Jun 15 2010, 11:58PM
Killa-X wrote ...
Where can I get one for $30?
Killa-X
Wed Jun 16 2010, 12:06AM
They are usually $50 but there's some people at laser forums doing $30...You just got to prove your worthy of using them...
Adam Munich
Wed Jun 16 2010, 12:08AM
I bought one of those WL arctic lasers. They use these diodes. I figured i'd just buy the ready-made laser because i'd have to machine a case for a diy laser anyway.
Killa-X
Wed Jun 16 2010, 12:13AM
Grenadier wrote ...
I manage to get mine for $196 with the 2 year warrenty :) I got in when it was free shipping, 10% off, and $20 warranty :D
WL claims its a TEM00 laser, but i highly doubt it. These are multimode diodes and make a ---- on your wall. It would be near impossible to get a TRUE TEM00 dot on the wall. And they claimed 1.5mm beam...Just got to wait and see!
Adam Munich
Wed Jun 16 2010, 12:15AM
Eh, i don't care about TEM. I have a green laser that mode hops and it's quite interesting watching those patterns change when i put it through a lens.
Killa-X
Wed Jun 16 2010, 12:21AM
Well, TEM00 is best for long distance pointing / beam. Else the distance you can see the beam at night is going to be short. Personal preferences. Where you get the 250mW green? O-Like? Rayfoss? My 200mW came from rayfoss :D
