  • Guests: 19
10/21 ben106 (40)
10/22 803 (2025)
10/23 Iniaes (17)
winding transformer for high frequency and current
Mon Jun 14 2010, 03:50PM Print
I have seen suggetions like copper tubing, litz and insulated copper strap. Where would I get insulated copper strapping? Also, is $4/foot reasonable for 1600 strand/#36gauge litz wire?
Does anyone have extra litz wire close to these dimensions?
Experimentonomen
Mon Jun 14 2010, 04:26PM
Try bundling up several litz wires, i just finished a new induction heater prototype, using the transformer from an old 3.5kW smps, it used litz wire for the primary and secondaries, bundles of several litz wires.
Mon Jun 14 2010, 04:30PM
Is this insulated strap reasonable?
Experimentonomen
Mon Jun 14 2010, 04:40PM
I think thats alittle thin for transformer use, copper strap i've seen in transformers was around 0.2-0.3mm or so thick.
Pinky's Brain
Mon Jun 14 2010, 04:58PM
What kind of frequency? At 100 KHz+ 20 mil is already over twice the skin effect depth, so at that point it's just about thermal conductivity/storage.
Mon Jun 14 2010, 05:35PM
Experimentonomen wrote ...
was this insulated?
where did you see it?
the copper strap i've seen is uninsulated
Mon Jun 14 2010, 07:59PM
This is where *I* would probably make my purchase:
amazed Finn Hammer amazed
Tue Jun 15 2010, 01:59PM
Thank you. I'm looking into this.
Right now I am winding one layer of wire. Is there any reason, if the conductor is flat, that I can't wind more than one layer? In other words, a 1/2" flat conductor, which has the appropriate cross-sectional area to handle the current at 20mil, will be too wide to get 20 turns in one layer. Can I keep going around in more than one like a regular transformer?
