  • Guests: 128
davovinch (75)
Duncan (37)
Vatorius (60)
waicool20 (27)
12/11 Forty (38)
12/13 williamn (48)
12/13 ReddyK (57)
Heuristics for propagation
coillah
Thu Jun 10 2010, 01:10AM Print
coillah Registered Member #1517 Joined: Wed Jun 04 2008, 06:55AM
Hi guys,
This is a very fuzzy thing to calculate manually. I was wondering if anyone knew from experience how well certain frequencies deal with propagation through/ around buildings, solid obstructions. I am trying to pick a band for some HSMM experimentation. Just wondering if anyone had any suggestions.
Thanks!
Dosinski
Thu Jun 10 2010, 04:45AM
Dosinski Registered Member #2680 Joined: Wed Feb 10 2010, 09:23PM
30 Hz is used by submarines. 300 Hz is used in deep mine shafts. Though I'm not sure how effective those frequencies are inside of buildings.
Hon1nbo
Thu Jun 10 2010, 04:48AM
Dosinski wrote ...
30 or 300 Hz for HSMM? - that's not right
HSMM stands for High Speed Multi-Media, which operates in the microwave range.
Have you considered the ARRL Microwave Handbook? - I have a copy I'm not putting to use somewhere, maybe I can find your information there, I'll take a look.
-Jimmy
EDIT: the Amateur Band which overlaps with the WiFi band is pretty reliable. A well placed antenna and a good antenna on the user end can work well in urban environments, but you are limited as you get farther away unless it is a strait shot - you could use "range expanders" with the WiFi band as they can seamlessly integrate things
Dosinski
Thu Jun 10 2010, 04:51AM
sorry, i completely missed that part xD
coillah
Thu Jun 10 2010, 04:16PM
I was thinking about setting up a temporary microwave repeater on a hill or something...
I am trying to rule out the possibility of using 33cm or longer bands. Atmospheric propagation is discussed and I can find results easily, but when it comes to LoS transmission through a building or something, nothing can really be said about penetration vs. frequency.
The ARRL handbook sounds promising though, I'll be looking that up today.
hboy007
Thu Jun 10 2010, 09:08PM
I guess I won't be of much help here but I once stumpled upon some interesting studies about wave propagation in tunnels, much like it is done here: Link2 and here: Link2
perhaps the drain system is worth testing *cough* .. just a thought wink you can't get your hands on a Multiphysics license, can you?
radiotech
Fri Jun 11 2010, 03:48PM
Change calculation to Nepers from Decibels and look in the acoustic field for insight.
