  • Guests: 38
Pylon (33)
ivest (29)
09/08 Addi (35)
09/09 Tonic (38)
09/09 earth3 (29)
High voltage rectifier
Matt Edwards
Tue Jun 08 2010, 09:41PM Print
Matt Edwards Registered Member #2838 Joined: Fri Apr 30 2010, 07:55PM
Hello everyone!
Does anyone have any good information (instructions) on how to make an inexpensive high voltage bridge rectifier?
I assume that I will be using many-many small diodes...
My biggest concern was arc-over between the diodes.
Any info will be appriciated!
dmg
Tue Jun 08 2010, 09:58PM
I typically use microwave oven diodes and solder the ends then put clear silicon glue on em, but ive seriesed 1n4007's to whatever voltage I need, then I put silicon glue on all the connections, then stick it inside 1 inch diameter PVC pipe and fill it with mineral oil
ive tried this method for up to 50kV with no issues
also, another method would be the one on the 4HV wiki:
which is really the same idea, but different construction
hope this helps
Wed Jun 09 2010, 02:53AM
use fast, avalanche diodes like steve ward does. the 1n4007's are slooooooowwLink2
Matt Edwards
Wed Jun 09 2010, 03:25AM
The rectifier is for the output of a mazilli zvs flyback driver. I am using a vary old flyback without the built in diodes. I am hoping to use the driver to power a small tesla coil but need to convert to DC before I can connect the capacitor bank.
Matt Edwards
Wed Jun 09 2010, 03:29AM
Patrick wrote ...
What diodes does "steve ward" use/suggest?
Wed Jun 09 2010, 04:49AM
SF1600 is the diode he uses but its hard to find now, and i wish i knew of a similar replacment.
Wed Jun 09 2010, 11:59AM
Patrick wrote ...
Patrick,
Firstly, they aren't hard to find.
Newark Electronics ALWAYS has them in stock and they are pretty cheap too. You can get a bag of 1000 pieces for $189.00.
Secondly, I offered you a full bag of 500 NEW EDAL MT4M5 diodes (1kV, 3A, 150ns) about a month ago for FREE ($6.00 for shipping) but you never took me up on the offer. Those diodes have since been given to someone else. Not sure why you didn't want them after I offered them to you.
Matt Edwards
Wed Jun 09 2010, 01:37PM
I like the SF1600's better then the 1N4007's, but the SF1600's will cost me $30 vs $5 for the 1N4007's.
I plan to use them to build a bridge from the HV output of two flybacks to power a small coil.
Is there an advantage in in this case for me to use the SF1600's?
Wed Jun 09 2010, 01:39PM
The 1N4007s will perform poorly, try UF4007s instead. (Ultra Fast version of the 1N4007.)
Wed Jun 09 2010, 02:25PM
eastern voltage, i got my pay pal thingy working now, and sent you the money last night.
also, yeah i think uf4007's would be fast enough for iggy type freqs instead of the more costly sf1600's for you.
the sf1600's are good for flyback freqs and up, 75ns trr if i recall.
