  • Guests: 70
Dual flyback ZVS driver
Matt Edwards
Wed Jun 09 2010, 03:59AM Print
Matt Edwards Registered Member #2838 Joined: Fri Apr 30 2010, 07:55PM
There may already be a thread about this but I could not find it...
I am considering connecting two flybacks to a single mazilli zvs driver circuit. Both flybacks are vary old and should produce AC. Does anyone have any recommendations as to how I should go about this? I know that newer flybacks producing DC should be connected (FB1 HV+) to (FB2 HV-).
Wed Jun 09 2010, 05:45AM
Duel is for pistoliers and shootists' , like alexander hamilton and aaron burr, you mean "Dual" not Duel.
And i would connect them anti-phased or you wont see twice the voltage, just twice the current.
-Patrick
Matt Edwards
Wed Jun 09 2010, 01:07PM
Patrick wrote ...
-Patrick
Thank you for the helpful advice...
Wed Jun 09 2010, 02:44PM
yep, yep
Thu Jun 10 2010, 09:33AM
You can connect them in series or parallel. Parallel is clear I think, for series connection tie the "cold" ends of the HV coils together (and ground them), and run the transformers in anti-phase. If you get no HV between the HV ends of the coils, change phasing of one of the primary coils (this is true also for parallel connection).
