  • Guests: 64
Etching Polycarb.
Maz
Sat May 06 2006, 09:27PM Print
Maz Registered Member #111 Joined: Fri Feb 10 2006, 01:04AM
im doing a fancy lighting project. i am painting a design reversed on some polycarb, then i need to etch all the areas that arent covered by paint. i need really clean lines, and a white finish.
im wary of chemical etchants because i need it even and i dont have experiance etching things.
is there an artificial glass etchant? like where it is just adds a frosted look, or should i use frosted privacy contact paper?
Bjørn
Sat May 06 2006, 10:59PM
There are products that come in spraycans that give a very good frosted look. Very fine sandpaper and lots of patience can also give good results if the pattern is not too intricate.
Maz
Sun May 07 2006, 02:51AM
do you happen to know what the spray stuff is?
sanding in out, i need a crisp edge and unless make certan you never touch it, the oil from your hands makes the sand job "frosted look" look bad.
Thanks!
Thingmaker3
Sun May 07 2006, 03:14AM
Thingmaker3 Registered Member #124 Joined: Fri Feb 10 2006, 01:30PM
You can get "etching cream" at most craft stores and some hardware stores. It's amoniowhatsis flourosomething with a thickener. Quite safe if one follows the lable instructions. Extremely easy to use.
Bored Chemist
Sun May 07 2006, 07:54AM
I think that ammonium bifluoride is nony meant for glass etching.
Sandblasting woul be good, but only if you happen to know someone with the kiot to do it.
Dr. Shark
Sun May 07 2006, 08:59AM
I agree with the chemist, etching plastics like acrylic is quite different from etching glass. I've had quite good results with boiling sulphuric acid when I accientially sprayed some on an acrylic screen, but I guess that wont help you.
Maybe you could use some organic solvent like acetone to "etch" (more like turn white) the stuff, but I doubt that it would be as accurate as you need it.
Wolfram
Sun May 07 2006, 10:31AM
Acetone whitens acrylic quite well, but it doesn't work too well with polycarbonate. You could maybe try out various organic solvents on a scrap piece.
Anders M.
Sun May 07 2006, 01:15PM
Possibly use an infrared laser (around 50-300mW ought to work).. :)
iirc IR is strongly absorbed by polycarbonate so this might just work.
-A
Sun May 07 2006, 06:25PM
I'm trying to persuade blackplasma to make me an edge-lit etched panel similar to this. I want green illuminated letters on a black background. He tried etching acrylic with a CO2 laser cutter on low power, and said that it worked well. I just need to get the artwork sorted out rolleyes
