  • Guests: 41
davovinch (75)
Duncan (37)
Vatorius (60)
waicool20 (27)
12/11 Forty (38)
12/13 williamn (48)
12/13 ReddyK (57)
Brightest UV LEDs?
Sun Jun 06 2010, 04:28PM Print
Hi all.
Found these
slight problem is they are 10mm. I can't seem to find any 1 or 10W diodes for sale in small quantities, this is for curing UV epoxy etc.
i was looking into shorting the leads, Dremelling them down to about 2mm thick then glueing ten together into a "pack" (oh the irony, uv glue needed) to make a 1W device suitable for scanning a substrate.
any ideas?
-A
Bjørn
Sun Jun 06 2010, 04:44PM
If you modify the package you will reduce both the maximum brightness and maximum power. The brightness because it is decided by how the light is focused and the power because you will reduce the ability of the LED to get rid of the heat.
To get 1 W out of 10 normal LEDs like that you need to run them smoking hot and the lifetime would be very short. An UV tube would be cheaper and a lot more powerful.
Sun Jun 06 2010, 04:54PM
hmm.
the ones i just found are 0.5W already so they would not need modifying.
Interestingly one idea that might work is to mount them in a block of BiSnPb alloy with one lead insulated with epoxy and heatshrink, then mount the flat block to a heatsink.
EDIT:- yes, they do need active cooling. I learned this the hard way with my previous experiments in UV PCB making that overheating them causes them to degrade quickly..
thanks for your advice.
-A
IntraWinding
Sun Jun 06 2010, 05:51PM
Where are the 1/2W diodes?
Mattski
Sun Jun 06 2010, 05:54PM
I'm pretty sure Luxeon used to have a UV LED for dental applications, I don't see it on their website but you might be able to find it on ebay or something.
If you wanted to take a more risky route, you could get a white LED and try to scrap off or dissolve the phosphor coating, because some of them contain a UV LED with phosphor coating, the same way a typical fluorescent light works. Sometimes though they are blue with a phosphor coating, or contain separate red, green, and blue chips.
Sun Jun 06 2010, 05:55PM
Do you need 400nm, or would 450nm work? I have found uv cure glues that *need* light shorter than 350nm, and other stuff that works great at 500nm.
If you can use 450nm you can go for one of the Casio projector diodes, which are 1w 450nm diode (the only downside is that they are multimode, so they give a kind of squareish beam, but its still better than a LED array!) I have a projector of them in the mail (with 24 diodes in it!), pm me if you are interested.
Sun Jun 06 2010, 07:59PM
The seller seems to tabulate most parameters but not the wavelength, where "UV" has been substituted for useful information.
I'd guess it wasn't UV at all, but 405nm violet.
There's UV-A, UV-B, UV-C and UVe-Been'Ad, a very common wavelength in LED retailing. cheesey
For pre-ionization and surface work function reduction in triggered gaps, I use a quartz UV tube. You can smell ozone within a few seconds of switching it on.
plazmatron
Sun Jun 06 2010, 08:17PM
Proud Mary wrote ...
About right there, 395nm at the absolute shortest wavelength.
The giveaway is the epoxy/plastic package. Deeper UV LED's are packaged in metal cans with silica output windows.
Deep UV LED's are available with wavelengths as short at 200nm, if you have the money!
Les
LEs
IntraWinding
Mon Jun 07 2010, 01:49AM
Roithner Laser in Austria have a nice range Link2
Prices for UV LED's start on page 47 Link2
Mon Jun 07 2010, 09:58AM
IntraWinding wrote ...
Roithners is the place to go alright - the Tiffanys of laser diodes.
