  • Guests: 45
Bill G (65)
Overclocked (38)
Edi (32)
09/21 Bill G (65)
09/21 Overclocked (38)
09/21 Edi (32)
driving a flyback with PWM?
haxor5354
Sun Jun 06 2010, 04:54AM Print
I recently built a 12v 200W PWM light dimmer for halogen lamps. it uses a 555 IC to generate PWM and a pot to adjust the duty cycle. im not sure about the frequency of th PWM but it can be easily adjusted by sawping a ceramic cap. so, will a high power/frequency PWM generator work as a flyback driver?
Matt Edwards
Sun Jun 06 2010, 01:23PM
Matt Edwards Registered Member #2838 Joined: Fri Apr 30 2010, 07:55PM
If you get a moment, post a schematic...
Pinky's Brain
Sun Jun 06 2010, 03:13PM
Haven't build one ... but if no one is going to jump in ...
I did google for schematics recently ... here's some :
This guy build the last one and has a youtube movie :
You just need to add the flyback and either a snubber (the second link) or a Zener+cap (the first link). Hell, might as well add both ... the snubber is there to damp oscillations, the Zener to protect the MOSFET from overly high drain-source voltage (although you can still kill it with high enough duty cycle simply by pulling too much current/power).
PS. this assuming you just want to draw sparks.
Sun Jun 06 2010, 03:19PM
Feedback-controlled PWM is routinely used in TV LOPT EHT regulation.
See this 1991 US patent granted to Sony Corporation, as one example only:
radiotech
Sun Jun 06 2010, 05:42PM
The Sony patent is interesting in that they divide down the EHT to drive the comparitor to adjust the duty cycle.
It would seem thay they were worried about X-Rays from the trinitron as it aged and presented less load. Other schemes of that era just had service personel set the HV with a probe.
condor
Mon Jun 07 2010, 03:59AM
condor Registered Member #2780 Joined: Mon Apr 05 2010, 12:39AM
Yes I have done it by winding around the exposed ferrite on a flyback from a monitor. Suprizingly powerful. And simple.
Two inch arcs off 12v pwm I built off drawings from here. Link2 There site is hard to navigate but quite alot of good info. Look under diy home pulse control circuits
