  • Guests: 37
10/21 ben106 (40)
10/22 803 (2025)
10/23 Iniaes (17)
Using an ADC
rp181
Sat May 29 2010, 04:00PM Print
I am using an XMOS proccesor for a project. I need some analog inputs for some sensors, and the XMOS does not have a ADC. I am confused on how to wire the AD7856 up. Datasheet:
Here is what I have connected now:
1-5v 13-
2-N/C 14-
3-GND 15-
4-5v 16-
5-5v 17-5v
6-GND 18-5v
7-5V 19-GND
8-? 20-?
9- 21-?
10- 22-?
11- 23-?
12- 24-?
Can some one look over this and advise what the "?" connects to and if I have the current pins connected right? I am confused as to the type of serial communication, it looks like I2C and normal serial combined.
wylie
Sat May 29 2010, 04:19PM
wylie Registered Member #882 Joined: Sat Jul 07 2007, 04:32AM
8 - Reference Capacitor
20 - DOUT
21 - DIN
22 - CLKIN
23 - SCLK
24 - SYNC
Without understanding that part in-depth, it looks like 20, 21, 23, 24 are the communications pins, where you get your data from.
Reconsider page 1 along with page 7.
Bjørn
Sat May 29 2010, 04:22PM
The datasheet seems to explain everything, it even has diagrams showing what to connect where.
The default communicaion interface is SPI, it transfers one data bit in each direction for every clock pulse. It can't be simpler, just read the part of the datasheet that explains it.
rp181
Sat May 29 2010, 06:05PM
SPI makes sense, I was under the impression the default was a serial connection.
Will try that, thanks.
