  • Guests: 41
10/21 ben106 (40)
10/22 803 (2025)
10/23 Iniaes (17)
stepper motor torque to overcome force
cavemen
Fri May 28 2010, 04:06PM Print
cavemen Registered Member #2008 Joined: Tue Mar 03 2009, 05:11AM
I am building the CNC machine.
The math that I have done, gave me a force that would oppose the motion of a gantry.
If I know the force the motor would have to overcome, how would I know the torque of the motor required?
J=F*d, I don't know d.
There is a lead screw mechanism involved and it is going to give the motor some mechanical advantage over the load. 1 revolution of the motor = 0.00254m of motion of the gantry part.
How do I know the torque it will take?
Thank you.
Fri May 28 2010, 04:20PM
I think you just multiply the force (in newtons) by that 0.00254, then by 2*pi because that's one revolution in radians, and that'll give you the required torque in newton-metres.
Dr. H.
Fri May 28 2010, 05:40PM
You can't calculate the needed torque (aquratelly) if you don't have the screw assembly. There is a big difference in torque requirement if you use a ball screw compated to delrin nut (for example).
I would advise you to first build the axis, place the load and measure the needed force to rotate the lead screw.
radiotech
Fri May 28 2010, 09:43PM
Steppers rotate in a circular pattern of jumps and after stepping, they bounce a bit then settle. You dont get smooth inertia.
The torque you need is in 2 parts Static and dynamic. Static is breakaway (just to jerk it to a start) and dynamic is after it is moving.
With a spring scale and a string around the shaft
you can get both.
Miight tbe what happens when single phase induction motors trys to replace 3 phase on lathes.
Torque pulsations at 2xline frequency impose a vibration on the machine that needs to be dealt with.
You might consider a Slo-Syn.
Eartaker
Sun May 30 2010, 10:56PM
Eartaker Registered Member #150 Joined: Sun Feb 12 2006, 09:43AM
Might also be better to us servo motors depending on the size of CNC you are building. I have build a 3 axis CNC mill and working on another. What are you trying to build or convert?
