  • Guests: 41
davovinch (75)
Duncan (37)
Vatorius (60)
waicool20 (27)
12/11 Forty (38)
12/13 williamn (48)
12/13 ReddyK (57)
Ingnition Coil Driver to Power Induction Heater
fatboyslim
Fri May 28 2010, 05:00AM Print
fatboyslim Registered Member #1779 Joined: Sat Oct 25 2008, 11:05AM
Hi
I was wondering if you could use a ignition coil driver and replace where the primary coil output would go to a separate coil which i can use as the induction heater coil. I have heard of people doing this, but is there a specific circuit you have to use in order for this to work?
For example can i use the circuit below?
Help would be most appreciated
Thanks
1275022824 1779 FT0 Et Iggie Driver
Fri May 28 2010, 10:48AM
It's not going to work. Look up some schematics and theory about induction heathers.
Fri May 28 2010, 11:34AM
Look at this: Link2 My iggy coil driver you have found isn't suitable, but I imagine any old 555 flyback driver running at around 200kHz would work.
fatboyslim
Mon Jun 07 2010, 08:24AM
Thanks for the reply's. Just wondering about the modified flyback drivers. Ive built a couple in my past and doesn't i usually operate at about 24khz or thereabouts. What kind of modifications would i need to make it oscillate at that high frequency?
Thanks
