  • Guests: 46
MC34063A DC/DC Boost Converter
killerbanjo
Thu May 27 2010, 12:51AM Print
killerbanjo Registered Member #2881 Joined: Wed May 26 2010, 09:55PM
Asdfasdf
Hey found this design on the old part of the website and wonderd if anyone has attempted it.
Also could i use the following parts (some of the resistors arnt quite the same) as it would save me some cash having to use one of the bigger sellers.
mc34063a - Link2
o.1uf (100nf) - Link2
500pf (470pf) - Link2
400R (390R) - Link2
5k (4.7k) - Link2
2.2m - Link2
10k Pot - Link2
FET IRF840 - Link2
1N5408 Diode - Link2
I have a few 150uH inductors lying around so i will not need them.
Thanks in advance - Ed
EDIT:
Check out this design Link2
^^^ No replys on a very old thread, tryed it out in falstad's sim and it worked good - ill remake it later to find out the outputs.
Thu May 27 2010, 02:34AM
killerbanjo wrote ...
2.2m - Link2
Welcome.
The design looks like a standard regulated boost converter.
Your component value selections/substitutions are fine except for these caveats:
1) 2.2m, I hope you mean 2.2M. SI symbols and prefixes are case sensitive. And in this particular forum, megohms and milliohms are both practical units of measurement.
2) The diode must be "fast" according to your schematic, and I think the 1N5408 might not qualify.
3) You must figure the FET on-time, thus the peak current in 150-uH inductor. Inductor must be big enough to handle that current without saturation. Please read the MC-whatever datasheet and any associated app notes.
4) I am regularly disappointed that these designs don't show any capacitor between the input voltage rails, physically close to the inductor and FET. Not required if the input power supply is stiff enough and close enough.
5) I don't see C3 in your bill of material. Since you posted in the projectile accelerator forum, I presume you have a large capacitor bank. You should also have a small HV capacitor hardwired to the output of the boost converter, allowing the converter to operate normally (for testing and for its own protection) when not connected to the big bank. With no capacitive load, each cycle of the switcher produces a high enough voltage for something to break down (FET or feedback resistor or coil insulation), and I don't know how the regulator will react.
Thu May 27 2010, 10:49AM
Hey
I'm working on an ic based cap charger at the moment too, Link2
Could you please post the specs on this? charge time? efficiency? cost?
My capacitor charger costs about $20 each and can charge 2.5 milli-farad in under 5 secs (according to datasheet) from a 12v source (battery)
hboy007
Thu May 27 2010, 12:06PM
I have two remarks on this:
a) put 1..2nF + 10..22R in series parallel to the diode. This will make sure no high frequency ringing occurs (during both forward and reverse recovery). Overshoot is approx. I_reverse,max * sqrt(L/C)
b) try an intermediate circuit voltage, this will double the circuit complexity but eliminate the "low Rds(on), high voltage rating" limitation
killerbanjo
Thu May 27 2010, 02:30PM
Klugesmith - C3 is the cap bank, i have a 450v 3000uf cap. and thanks for taking the time to write that for me, a real help.
hboy007 - Thanks for your suggestions!
and GhostNull - I didnt come up with this schematic and i cannot find any specs however, the ammound of parts are so small that i think ill give it a go as it will only cost me a few £££ + £1.50 postage (I love bitsbox :D)
Thu May 27 2010, 03:17PM
Re the other comments, try a UF5408 diode instead of a 1N5408.
Also a decent-sized electrolytic capacitor ("decoupling capacitor") between the +12V and ground would be a good idea. 470 or 1000uF, 16V, say.
The industry-standard way to overcome the Rds(on) vs. voltage tradeoff is to use a transformer instead of an inductor, changing the circuit from a boost converter to a flyback converter.
