  • Guests: 43
seveerz (69)
10/21 ben106 (40)
10/22 803 (2025)
10/23 Iniaes (17)
Rectifying mains
HazzWold 1993
Wed May 26 2010, 01:55PM Print
Hey this may be a stupid question but how can i go about rectifying 240VAC 50Hz mains. i have 385VDC capacitors that need charging to some degree.
i have a 3 phase bridge rectifier. could i use a single phase from that? or... what.
dmg
Wed May 26 2010, 02:10PM
well, a simple bridge rectifier that you can get for less then a dollar will do, Im not sure about the 3 phase one though (six pulse I assume)
you can still rectify it on the three phase by using the first 2 connections, but Im not sure what effects will happen from that extra diode pair.
lpfthings
Wed May 26 2010, 02:18PM
lpfthings Registered Member #1361 Joined: Thu Feb 28 2008, 10:57AM
Just find a "bridge rectifier". Because of your voltage and mains frequency, I assume you are in Australia or Europe, in which case, one of these should do it: Link2
Also, if you are using mains to charge a capacitor directly, without a transformer, you will need a NTC thermistor to prevent the initial surge current from tripping your breakers and blowing up your rectifier and capacitor. Link2
Wed May 26 2010, 02:20PM
I used two 450vdc capacitors in series for a total of 900vdc. I bought a bridge rectifier of suitable amperage and mounted it to a heat sink. My rectifier is set up as a doubler using 240vac and easily handles 40-50a
Bjørn
Wed May 26 2010, 02:35PM
Connect two of the inputs, if the third looks lonely you can connect it to one of the other two. You can use a 240 V lightbulb in series to limit the inrush current so you don't blow the rectifier or the mains fuse. Be really careful and don't leave any exposed connections that curious people can touch.
HazzWold 1993
Wed May 26 2010, 11:23PM
lpfthings wrote ...
With the thermistor do i have it in parallel to the mains or in series with the hot line? also should it be rated above the rated ratings of my house power. our plugs are all 15 amp lines and that one you gave a link to is rated only to 10 amps.
Also. would a 400 volt 35 amp bridge rectifier be okay?
HazzWold 1993
Wed May 26 2010, 11:29PM
Actually to just get the thermistor out of the picture.
What would be a suitable transformer to have in there. could i run a MOT into another MOT run in reverse? it would probably leave me with very low current though.....
???help
dmg
Wed May 26 2010, 11:55PM
running two mots in that configuration will probably leave you under the 10A output, since ive used that to ballast MOTs.
(never actually messured the current) but I will tell you it most definatly pulled under 10A since the fuse did not burn out.
if you need more current, then you may need to remove the shunts from those 2 transformers.
by running these 2 mots in reverse, you are reffering to
input power - primary - secondary to secondary - primary - output?
HazzWold 1993
Wed May 26 2010, 11:59PM
gatedbreakdown wrote ...
Yes thats the configuration im reffering too.
Would it be suitable?
dmg
Thu May 27 2010, 12:03AM
I belive it will, there was a small amount of inrush upon startup, but the outer mot showed no noticable inrush current , or atleast to the point where it should be off any concern when I ran a MOT off this setup, and both MOTs were identical units.
also, when I run this, I used MOTs with shunts in them (unmodified whatsoever)
It will probably be a good idea to messure the output current from your setup
