  • Guests: 42
seveerz (69)
10/21 ben106 (40)
10/22 803 (2025)
10/23 Iniaes (17)
opto-isolator for a parallel port
cavemen
Sun May 16 2010, 06:25PM Print
cavemen Registered Member #2008 Joined: Tue Mar 03 2009, 05:11AM
hello
i am trying to resolve a simple engineering problem of optoisolating my parallel port (17 pins)
and a controll board that would run steper motors
is there an optocoupler chip that has that many channels?
all the chips that i had found are either 4 channel or 1 channel and are all very large in size and i would need a lot
thank you
(i am working on two projects and researching one as i am waiting for parts for another)
radiotech
Sun May 16 2010, 07:25PM
How many of the 17 pins actually step the motor? Do you need any bidirectional functions on that port?
cavemen
Sun May 16 2010, 10:13PM
good question
i will research that
thank you
Bjørn
Sun May 16 2010, 10:37PM
You also need to define what you are trying to protect yourself against, maybe there is a much simpler way around the problem.
