  • Guests: 32
10/21 ben106 (40)
10/22 803 (2025)
10/23 Iniaes (17)
bleeder resisters
quicksilver
Sun May 16 2010, 05:21PM Print
Why don't bleeder resistors form a short circuit when in parallel on a filter cap? It just seems Illogical for that not to take place...
I made a small DC supply using a small variac rectified and the filter cap is a real danger as well as a nuisance for certain applications. I was going to put a bleeder on it when this question arose: I just don't get it. Is it that the formula for a bleeder's value is such that a short can't take place?
CT2
Sun May 16 2010, 05:57PM
CT2 Registered Member #180 Joined: Thu Feb 16 2006, 02:12AM
A short circuit would mean no resistance, a bleed resistor has resistance (ovbiously) and therefore isn't a short. The resistor does constantly bleed the capacitor, but the resistors value is high enough that it doesn't actually dissipate much power. Its value is picked such that the RC time constant is a safe value for your application. For example if you want the capcitor to be discharged 2 seconds after power is turned off, you would have to pick a resistor value to go with your capacitor value such that R*C = 2 seconds (it will only be discharged to 37 % by this point however). And then you would need to use the voltage across the resistor to determine the current, and I^2*R to pick the power rating of the bleed resistor.
quicksilver
Sun May 16 2010, 06:19PM
Thank you for taking the time. I really appreciate it.
It occurred to me later that since there was resistance a true short could not take place but often I still think of the analogy of "running water" when conceptualizing electricity; so that circuits would all be simplistically linear. smile
radiotech
Sun May 16 2010, 11:56PM
There is another reason for a bleeder resistor. The DC value for full wave rectifiers is 0.636 * peak AC . However with no bleeder resistor,
if a capacitor is used, the voltage across it would rise to the peak of the AC under no load conditions which could overvolt any load suddenly switched on. In addition more expensive capacitors (higher voltage) woud be needed.
quicksilver
Mon May 17 2010, 01:56PM
I didn't know the numeric element but I did see that phenomenon in testing with a meter. I thought it was odd at first; so used to seeing on the meter, what is projected in the circuit design. .....But it was there. I did know the need for higher value - high quality filter caps. Mains AC current has so many issues that even though I had a slight background in commercial electrical work, I still find more subtle issues, the more I explore.
EE students have a serious advantage over those who haven't had that background. I am just now studying that material that 1st year engineering students would know.
Mon May 17 2010, 02:30PM
radiotech wrote ...
That's only true for a choke input filter, and those are hardly used nowadays.
radiotech
Mon May 17 2010, 04:33PM
The average value is used for rectified AC converted to DC amps
for things like chemical cells and motor efficiency calcs.
An electric heater will get hotter on AC than it will on fullwave rectified DC. 1.11 times hotter.
Mon May 17 2010, 06:47PM
Steve McConner wrote ...
radiotech wrote ...
I still use them, not because they're the best, nor that they are simple enough for me to understand, nor again that this kind of circuitry lends itself well to a 40W soldering iron, but simply because I can, and that I love the look of those glossy, black, oil-filled Parmeko chokes. My idea of a bleeder resistor is something which can augment the central heating in the winter time. smile
Tue May 18 2010, 10:36AM
Well, if you've got some of those Parmeko chokes, it would be a shame not to put them to use smile It's hard to get chokes designed for choke input filter service nowadays. Audiophiles love the Parmeko stuff, I've seen a pair of Neptune output transformers go for over £500 on Ebay.
Of course, buck and forward converter SMPS are closely related to the choke input filter, and they need a minimum load or a bleeder resistor. Different century, same problem smile
Radiotech: You're (deliberately?) confusing RMS and average. The electric heater heats according to the RMS value, an electrochemical cell or battery responds to the average value.
The 1.11 factor you give is the RMS-to-average ratio for a DC supply fullwave rectified from single-phase AC and unsmoothed. If it measures 240V DC on your Simpson multimeter, which being a moving-coil instrument reads the average, then it'll actually be 266V RMS.
radiotech
Tue May 18 2010, 05:32PM
moi?
The clearest statement I have seen is in this paragraph shown:
And this Simpson model 20 could be used to measure " power effectiveness"' , it being a thermocouple type.
1274203948 2463 FT89307 Scan0019
1274203948 2463 FT89307 Simpson20
