  • Guests: 41
williamn (48)
ReddyK (57)
Birdman (31)
12/14 M.A.D. (32)
12/15 marko666 (58)
12/16 Will T (16)
Baby oil as transformer oil replacement?
dmg
Sat May 15 2010, 10:00PM Print
I was dabling with several oils to test out to see what can I use as a permanent replacement for transformer oil (that was specifically designed for transformers).
so I desided to try out baby oil, since it is far cheaper, and I was told that it pretty much is mineral oil.. having a small bottle on, hand, I had not had high hopes for it, because it had some additives in it, but when I tried it out with a 15KV/30MA NST, It held well, no corona, no arcing, nothing.
So before I go crazy and start dumping this stuff into transformers that are going to be sealed permenantly, has anyone used this product before for long periods of time? If so, has it held up well?
Sun May 16 2010, 12:45AM
Baby oil is 'mineral oil' with perfumes to make it smell agreeable.
For environmental reasons 'mineral oil' is falling from favour in high voltage power transformers, and is being replaced by vegetable oil dielectrics.
Kitchen sunflower seed oil is an excellent dielectric material, and most vegetable dielectric oil patents use combinations of sunflower seed oil, rape seed oil, maize oil, and so on. Do a Google search using the terms "vegetable dielectric oil" and you will find dozens of papers and patents on the subject.
dmg
Sun May 16 2010, 12:53AM
Thank you for clearing that up mary,
also, this oil has aloe vera and vitamin E in it, and when I smelled it, it smelled pretty nice, which kinda discouraged me about using it for transformers, since the oil I used to use is more of a greenish tint, and has a distinct odor.
for reference, here is the picture of one of the bottles.
-scented transformers anyone?
1273971220 2628 FT89258 Baby 001
1273971220 2628 FT89258 Baby 002
Killa-X
Sun May 16 2010, 04:18AM
Could always perform a test with it if you're not sure. However, like stated there's many other alternatives. I usually go to the hardware store and get boiled linseed oil. Costs a dollar more here to get 1 gallon of boiled lineed oil. This way it has no impuritys...
Sun May 16 2010, 09:09PM
gatedbreakdown wrote ...
I wouldn't bother about some milligram quantities of oil-soluble Vitamin E and whatever soluble substances there are in aloe vera. A lot of scented products are scented simply to obscure the odour of the other ingredients.
You're not dealing with high voltage transformer dielectric oil that must remain stable for five years continuous use, are you?
dmg
Sun May 16 2010, 09:21PM
Proud Mary wrote ...
Perhaps... wink
no really though, the oil will probably not see more then 10KV.. and I just plan on sealing it inside a container with the transformer in it, I guess you are right, such a miniscule amount wont affect performance..
just perfume for transformer oil basicly...
Sun May 16 2010, 11:18PM
Perhaps... wink
You could paint it pink, too! smile
Bored Chemist
Mon May 17 2010, 07:50PM
Boiled linseed oil is designed to turn into a sticky mess. It's also sufficiently reactive with air to be spontaneously flammable in some circumstances,
radiotech
Mon May 17 2010, 07:51PM
Here's a test device; you might be able to copy it.
After zapping the vegetable based medicated oil it could be examined (carefully) for new and interesting long chain mollecules.
1274125875 2463 FT89258 Oil
Mon May 17 2010, 08:07PM
Do remember that the oil will expand when the transformer warms up.
Approaches to this problem range from leaving a free space above the oil inside the case filled with non-reactive non-flammable gas, having a vent which will open at a given pressure, or by using compressible materials or objects inside the casing.
If you don't take care of the pressure problem in a sealed unit in one way or another, the very least problem will be leakage.
