  • Guests: 51
10/21 ben106 (40)
10/22 803 (2025)
10/23 Iniaes (17)
Simple PSU Circuit Help
Matt Edwards
Tue May 11 2010, 03:28AM Print
Matt Edwards Registered Member #2838 Joined: Fri Apr 30 2010, 07:55PM
After considering the good information that everyone was so kind to provide me, I have decided to try something else.
How would I modify a circuit similar to the one below to produce 12-24v rather than 0-24v? It doesn't have to be exactly 12-24v. It is just a ball park figure.
This is beyond my current knowledge of circuits.
1273548486 2838 FT0 Lm3173
Tue May 11 2010, 09:11AM
Put a fixed resistor in series with the 5k pot. I won't calculate the resistor value for you.
Matt Edwards
Tue May 11 2010, 09:34PM
Thanks for the help
Matt Edwards
Wed May 12 2010, 05:04AM
I believe that I have asked a question in which I already knew the answer to.
Wed May 12 2010, 07:55AM
At page 11 in the datasheet you took the screenshot from there is a interesting 4A 4,5 - 25 V regulator example, using 3x LM317 and a opamp.
You should give that a try after you complete the first :)
Matt Edwards
Wed May 12 2010, 01:27PM
Thanks. I am worried about heat dissipation so i am working on alternative solutions to the poblem.
Zeus
Wed May 12 2010, 11:04PM
Zeus Registered Member #2316 Joined: Tue Aug 25 2009, 03:04AM
Try a bypass transistor TIP35C, it handles 15A.
