  • Guests: 20
  • Most ever online: 441
    Guests: 441, Members: 0 on 01 Oct : 16:32
TwirlyWhirly555 (33)
10/04 Michael W. (36)
10/05 GhostlyFigures (36)
10/06 Ivan Kalafatic (17)
EMF
GhostlyFigures
Sat May 08 2010, 11:47PM Print
GhostlyFigures Registered Member #2385 Joined: Thu Sept 24 2009, 01:26AM
Location: Waxhaw, North Carolina (Or Charlotte near UNCC)
I was wondering if anyone had built an EMF detector. It would be cool to have and I would like to make one instead of buying one. That is, of course, if it's cheaper. Didn't know if there was some kind of complex circuitry at all.
radiotech
Sun May 09 2010, 04:40AM
What do you mean by EMF ? Where do you expect to measure these and what do they come from?
Lethal Shot
Sun May 09 2010, 08:59AM
Lethal Shot Registered Member #1623 Joined: Tue Aug 05 2008, 03:31PM
Measuring EMF is very difficult, first you would need a faraday cage because else it will be impossible to seperate the noise from the signal.
Then you would need an antenna that is built for the frequency range you would like to measure and connect that to at least a spectrum analyser.
There is specialized equipment for this only I don't know the english terms for these devices.
But it is very hard to get an accurate measurement, the theoretical maximum accuracy (at the moment) is +- 4,8dB and that is with state of the art equipment.
And this is just for measuring the field at 1 point so you only know the field at a given distance from the source.
I don't know why or what you want to measure exactly but measurement of EMF is very hard.
Sun May 09 2010, 10:09AM
If you mean a meter for detecting direct current magnetic fields, such as terrestrial magnetism, we would call such an instrument a gauss meter, or magnetometer. A compass needle is the simplest possible type of magnetometer.
A very basic instrument for detecting alternating magnetic fields, such as the field around power pylons, or around a television, need not be hard to make on a small budget.
If you'd just like to tell us a bit more about what you hope to do with your EMF detector, it will be easier to come up with a more definite answer.
IntraWinding
Sun May 09 2010, 11:52AM
My understanding is that "EMF" (Electromotive Force) is just an old term for voltage so to me you appear to be asking "How do I measure voltage". Presumably you don't mean this, so can you say a bit more about what you want to measure?
Sun May 09 2010, 02:01PM
I thouht that EMF stood for ElectroMagnetic Field... confused
lpfthings
Sun May 09 2010, 02:50PM
lpfthings Registered Member #1361 Joined: Thu Feb 28 2008, 10:57AM
EMF detectors for lightning work well and are quite simple. You need to tell us what sort of EMF you are looking at here.
Turkey9
Sun May 09 2010, 04:44PM
The only EMF meter I've heard of is used for looking for ghosts! tongue
radiotech
Sun May 09 2010, 05:10PM
EMF E,M.F. ( ELEC, ENG.) a commonly used abbrev. for electromotive force. The force which causes electricity to move around a circuit--from CHAMBERS'S technical dictionary , 3rd ed. 1940. (with supplement 1958.
Here's my meter for terrestial magnetism.
And the instructions for use.
1273425015 2463 FT88835 Scan0003
1273425015 2463 FT88835 Dipneedle
Mon May 10 2010, 12:46PM
If you are talking about visualising magnetic fields tesladownunder made a hall effect sensor array Link2
