  • Guests: 38
seveerz (69)
10/21 ben106 (40)
10/22 803 (2025)
10/23 Iniaes (17)
mosfet blocking diode
Sat May 08 2010, 06:40AM Print
Does it matter, other than for very fast switching speeds, if the blocking diode is a schottky or ultrafast diode?
Schottky's only can block 30-50v, while an ultrafast diode can go much higher. If this is the case, why is the greater part of the voltage drop across the source-drain of the mosfet instead of the blocking diode?
wylie
Sat May 08 2010, 05:33PM
wylie Registered Member #882 Joined: Sat Jul 07 2007, 04:32AM
Didn't this get covered in the FET Vs IGBT thread a few days ago?
Re-Read The Master (scroll down to the "Beware the MOSFET body-diode !" section. Where's the html anchors richie?! wink )
