  • Guests: 33
10/21 ben106 (40)
10/22 803 (2025)
10/23 Iniaes (17)
High frequency and breadboards???
Matt Edwards
Fri May 07 2010, 06:18AM Print
Matt Edwards Registered Member #2838 Joined: Fri Apr 30 2010, 07:55PM
Hello, I was browsing around and found statistics that stated breadboards are generally rated for 10khz and below. I am trying to use a breadboard for a ZVS flyback driver. Does anyone have any real information for solderless breadboard specs???
Kipmans
Fri May 07 2010, 07:58AM
Kipmans Registered Member #91 Joined: Thu Feb 09 2006, 03:03PM
I would be more worried about the currents you're going to drive through those contacts than the switching frequency being too high.
Fri May 07 2010, 09:29AM
Spot the breadboard? That's 300W at 4MHz.
wylie
Fri May 07 2010, 11:20AM
wylie Registered Member #882 Joined: Sat Jul 07 2007, 04:32AM
How the.....I've melted the holes on my boards with as little as 150W at just a few kHz. Is there anything Richie can't do? (though, to be fair, those blue ones look a bit heftier than the radioshanty breadboards)
Matt Edwards
Sat May 08 2010, 03:23AM
I am just planning to use it for a quick test run.. I already toasted one board.
