  • Guests: 48
10/21 ben106 (40)
10/22 803 (2025)
10/23 Iniaes (17)
spoofing a Li-ion Battery Pack
Hon1nbo
Thu May 06 2010, 11:13PM Print
hey guys, I need to spoof a li-ion battery pack so I can power one of my cheap cameras with a different power source, in this case my ROV battery with a voltage regulator
the battery has three connections: +, -, and "T" - I assume that the "T" pin is stopping me from just hooking the camera up to a voltage regulated supply, which has so far failed.
I have no idea what I have to do about it, and I don't even own a charger for these batteries anymore and nonetheless know where to get this model. It's for an old Aiptek camera, at least six or seven years old.
-Jimmy
Fri May 07 2010, 09:33AM
Hi Jimmy
The "T" terminal is normally for temperature sensing. Inside the battery should be a 10k @ 25'C NTC thermistor connected between "T" and "-".
So try connecting a 10k resistor between T and - on the camera.
Some smart battery packs use the T terminal to communicate using a 1-wire serial protocol, in which case you might be out of luck.
Sat May 08 2010, 12:19AM
heh..
i did something like this using a dead motorola pack.
had a phone where the battery was made of unobtainium, so took the old dead pack apart and salvaged its pcb.
added a nokia cell across the internal terminals and voila.
worked fine for a week or so until i got my main phone back.
-A
#include "Li_Ion_Go_BOOM.h"
