  • Guests: 64
10/21 ben106 (40)
10/22 803 (2025)
10/23 Iniaes (17)
Help interpreting datasheet for IGBT
Wed May 05 2010, 02:21AM Print
I was reading this datasheet and it raised a question. At 25c it is rated for 75A; it is rated for 63A at 110c. On the upper right corner of the first page it says that it does 40A at 100khz @ 390v; it does 20A at 200khz @ 390v. Does this mean that even though it is rated for 600v and 63A (if the temperature permits), it can only do 20A if the switching speed is 100khz?
If have seen other chips that don't have this frequency specification.
So, what can I make out of this information?
doctor electrons
Wed May 05 2010, 03:40AM
i did not look at the datasheet but yes, frequency will drastically affect operational limits. think of it like duty cycle. 80% 20% of the time,
or 60% 40% of the time. temp and freq are important.
Wed May 05 2010, 09:10AM
It's a complicated way of telling you the switching losses.
ScotchTapeLord
Wed May 05 2010, 12:51PM
Doesn't that assume hard switching, though? You can probably pull a little more current with a resonant load.
Wed May 05 2010, 01:38PM
Yes. But I don't know how to calculate *how* much more.
ScotchTapeLord
Wed May 05 2010, 01:50PM
I read something that gave some efficiency percentage values on ZCS and ZVS, but I can't seem to find it right now... I think it was by TI. I remember that ZVS was much more efficient than ZCS, but that ZCS still offered like ~20% extra efficiency. I'm sure it varies greatly with the IGBT and the system, though. Probably better off running close to spec and only upping the power if everything is cool.
radiotech
Wed May 05 2010, 03:34PM
Fig3 of the curves gives the f vs I ratings. Rated values are what the manufacturer warrents the device to withstand.
