  • Guests: 29
10/21 ben106 (40)
10/22 803 (2025)
10/23 Iniaes (17)
connecting high current semiconductors to heatsinks
Mon May 03 2010, 03:38PM Print
Many high current devices (igbt, mosfets, diodes) have one of the terminals connected to the metal casing and a through-hole pin. THis casing gets mounted to a heatsink. Is there any difference with regards to heat dissipation or conduction if one connects the circuit to the case or the pin lead?
Dr. Slack
Mon May 03 2010, 08:38PM
Look at the data sheet, different devices use different standards. Some say you can connect electrically through the heat tab, some say you must put all the current through the pin, but keep the heat tab at the same potential. If there's 10s or 100s of amps involved, then I guess it's a smart idea to do what the data sheet says.
Mon May 03 2010, 08:51PM
I've always treated the tab and the centre pin as interchangeable. They're both physically the same piece of metal, and the silicon die is attached to it by solder that carries both the heat and the current away.
I've built high-current circuits where TO220 MOSFETs were clamped by their tabs to a busbar that carried the current and acted as a heatsink. I cut the centre pins off.
In some power ICs, there may not be any pin that's a physical part of the tab, and I guess this is the scenario where Dr. Slack says all the current must go through the pin. But this isn't the case for any MOSFET, BJT or IGBT in a 3-pin TO220 or TO247 that I know of.
In a TO-3 the case is the collector, but the tab/pin thing is really the same as that.
Edit: With diodes it gets a bit more complicated. Some high voltage diodes come in two-pin TO247s, and are made of two diodes in series internally. I wouldn't be surprised if the tab was connected to the centre point of the two diodes.
quicksilver
Tue May 04 2010, 02:08PM
Steve McConner wrote ...
An exception I found was on one of the more powerful IGBT's that I know of: the Toshiba GT60N321 is a TO-247 case but the metallic back is covered so it demands that you use the pins. This is a sweet transistor with 1K collector-emitter voltage, collector current 60A, at 170W. I used it before on several projects & it was always worth hunting for or buying from Mouser. It's like a tank!
