  • Guests: 27
10/21 ben106 (40)
10/22 803 (2025)
10/23 Iniaes (17)
Variac tap?
dmg
Sun Apr 18 2010, 02:31PM Print
does anyone know why some variacs have taps on their windings?
this is a 120V variac, so my assumption that the tap is 120 and the rest of the windings go to a higher voltage.
1271601092 2628 FT0 Var 001
1271601092 2628 FT0 Var 002
also, there is a second tap on the other side of the variac
Sun Apr 18 2010, 04:07PM
Most variacs have a tap that you can connect the incoming mains to for boosting. For instance on a 240V one, you can go from 0 to 240 by connecting the whole winding up, and 0 to 270V by using the tap.
Also, I've got one that has a 24V tap at the neutral end for powering a pilot lamp.
dmg
Sun Apr 18 2010, 04:22PM
ah okay Steve, so If I understood right, I can connect this variac to my 120V mains, and using the tap get out 140 or so?
radiotech
Sun Apr 18 2010, 07:20PM
Variacs can be used as variable inductors too. With the tap and a few other parts, you could make your variac into a variable sin oscillator to control the speed of syncronous motors like the one used on a Hammond organ. "Hammond Organs- can never be tuned, yet never can go out of tune"
