  • Guests: 37
seveerz (69)
10/21 ben106 (40)
10/22 803 (2025)
10/23 Iniaes (17)
Help Identifying Puck SCRs
Turkey9
Sat Apr 17 2010, 09:34PM Print
I found two of these recently at a scrap yard with all mounting hardware and heatsinks and clamps and such. The only problem is that I can't find the data sheets anywhere! Even the manufacturers web search for discontinued parts doesn't have it! The other devices that look like mine on the Eupec site are rated over 1400v with 700amp average current, but I would like to have the actual data sheet and not have to guess rating. There are no engraved part numbers, just a sticker on the side. It reads....
eupec Thyristor 34-1510 20E9
Here are a couple pictures of it.
1271539554 1451 FT1630 Scrside
1271539554 1451 FT1630 Scrtop
radiotech
Sun Apr 18 2010, 05:40AM
Have you a picture of the pressure clamp that held them in ?
Turkey9
Sun Apr 18 2010, 10:11PM
here's the clamp. It's not bolted together and the SCRs are removed, but that's about the placement that they were in.
1271628556 1451 FT1630 Scrclamp
radiotech
Mon Apr 19 2010, 05:16AM
Somewhere here I have some scr's like that, made by GE. In very large DC drives, scr's were changed if they failed an insulation resistance test done with a 600 volt megger. The issue with heatsinks we used was the critical torquing on the bolts used to press the puck between the halves. Whether or not the scr might have caused a problem with the leakage A-K was never known. Those big drives used to trip on an IOC fault (instantaneous Overcurrent) and started up after reset with no real apparent
reason. We then would hook a 4 channel chart recorder up and look at that for a while. Certain stunts on the grid were avoided until the power control operators called the process operators to warn then.
Curtis
Wed Apr 21 2010, 07:24PM
Curtis Registered Member #883 Joined: Sat Jul 07 2007, 01:02PM
the large gauge of wire going to the gate suggest that this may be a GTO thyristor, where a large negative pulse is sent to the gate to commutate conduction. Here at work we have a set of 750Kva VFDs that use this technology. Old but Robust.
Turkey9
Wed Apr 21 2010, 09:51PM
So if it turns out to be a GTO thyristor, then I just drive it negative in the same fashion that you would drive a normal SCR of that size?
Curtis
Sun Apr 25 2010, 08:00PM
To turn it on take the gate positive just like any other SCR. But it can be commutated by applying a negative pulse to the gate. I think most SCRs will commutate in this fashion but a GTO is made to take this "abuse". It also takes substantially more current to turn them off then to turn them on.
