  • Guests: 56
A cross-ref for SF1600 diodes. HELP plz!
Sat Apr 17 2010, 06:11AM Print
hey all,
i need help finding SF1600 diodes or similar, is there a way to find an equivelnt part to SF1600 by a different manufacturure instead of Vishay. mouser, digikey and others seem not to have it, but i need 2,000 of the buggers for my college project.
it must be a fast, avalanche rated, HV diode.
i use many of these in series for a 22kV pk-pk full wave bridge rectifier, at 100kHz.
any help is appreciated.
Here is a pdf :
]sf1600.pdf[/file]
MinorityCarrier
Sat Apr 17 2010, 05:37PM
Newark Electornics quotes a 50-day lead time.
Check out Semikron.
You might Chinese equivalents, that may even prove to be real, out in the wilderness. Welcome to the world of backlog ordering, happy hunting.
Sat Apr 17 2010, 10:00PM
DAM, DAM, DAM! mOUSER QUOTES A 14 WEEK LEAD TIME !!!! cowards!!!!
TY minorityCarrier
-Patrick
Matt Edwards
Sun May 09 2010, 04:26PM
Matt Edwards Registered Member #2838 Joined: Fri Apr 30 2010, 07:55PM
Try searching NTE for an equivalent. You can also call/email them. I had a similar issue with HFA15tb60 Diodes and was able to find something similar through NTE.
Mattski
Sun May 09 2010, 06:31PM
Found this on a digikey parametric search, seems pretty similar: Link2
It has the same 75ns reverse recovery time . I'm not sure how the forward recovery time will impact your project, but at 500ns which is 5% of your 100kHz period it's probably not too bad.
