  • Guests: 44
reading hv
condor
Sat May 08 2010, 09:08PM Print
condor Registered Member #2780 Joined: Mon Apr 05 2010, 12:39AM
Im new at this what is a good way to build something to read high volts, ampes, and be able to scope the wave form. Oh yeah without buying super expensive equipment.
wylie
Sat May 08 2010, 11:10PM
wylie Registered Member #882 Joined: Sat Jul 07 2007, 04:32AM
Digital Multimeter or those bouncing-needle panel meters can be had on-the-cheap.
condor
Sun May 09 2010, 02:07AM
I wasnt aware you could get multimeters in the 40 kw scales.
I know power utilities had meters .
maybe i stated the question wrong how do I read volts up 100kw on my multimeters and oscope ?
radiotech
Sun May 09 2010, 04:57AM
here is a handheld meter that can measure 300 kW and
here is a probe for a multimeter to measure 50 kV
1273381064 2463 FT88827 Kw
1273381064 2463 FT88827 Kv
Turkey9
Sun May 09 2010, 05:12AM
For current, if it's AC you can use a current transformer or a rogowski coil, both of which can be made cheaply. If you're measuring DC, you can use a very small value resistor and read the voltage drop across it.
condor
Sun May 09 2010, 03:14PM
Thanks guys for the input. It is greatly apprieated. Im trying to build a test station, but all I found was meters that went to 500 v ac
Matt Edwards
Sun May 09 2010, 04:19PM
Matt Edwards Registered Member #2838 Joined: Fri Apr 30 2010, 07:55PM
You can build a inexpensive HV probe to be attached to your multimeter. Here are a few links. (google is your friend) Try searching for subjects like DIY HV PROBE, DIY HV METER. You can also search HV probe on ebay (make sure to exclude -oscilloscope to limit the search). There are usually a few independent probes with meters built in. Also, I believe that fluke has a probe that attaches directly to the multimeter.
Turkey9
Sun May 09 2010, 04:49PM
I have the fluke probe and it fits right in your meter! At least mine that I got at radio shack. I bought mine on eBay for $15 and it's worked great so far. Good to 40kV.
radiotech
Sun May 09 2010, 08:28PM
"I have the fluke probe and it fits right in your meter!"
A good rule with Fluke instruments and very high voltage probes is to make sure they belong to those paying you to use them !
My Fluke 87 hides in metal case and lives to see another day.
condor
Mon May 10 2010, 12:44AM
I hear ya radio tech. i think i accidently got over 100kv . The arc jumped about a foot and got me. "I pissed myself and forgot who I was for a half hour"...lol
I has messing around in the hertz freq so I figured when I hit the kh i better have a better plan.
Just kidding about pissing myself.
I used the one hand rule
thanks odium 45 just what I was looking for . I searched like crazy on bing no luck I guess Im going to have to range out.
turkey9 Im a mechanical designer, so when no one could answer my question I went back and had to reteach myself electronics. Havent used it for 25 years..lol
so I keep my flukes and oscope safely in the box too, til i figure it out with cheap meters.
Its changed alot since the old tubes....lol
