  • Guests: 102
A car project ... an exploding wire lightning simulator
Tesladownunder
Sun Apr 11 2010, 10:42PM Print
Here is the first pic from a new project..
BTW this is a "loaner".
1271025732 10 FT0 Junkcargrindingroof
Chris Cristini
Sun Apr 11 2010, 11:22PM
That is funny What are you doing.
HazzWold 1993
Sun Apr 11 2010, 11:35PM
More pics please!
Tesladownunder
Mon Apr 12 2010, 01:21AM
I suppose I could show one more.
I was thinking of mounting this intergalactic beam weapon on top. Should I be saying this? Do you have clearance?
1271035150 10 FT87297 Michael18thsmokerings
Myke
Mon Apr 12 2010, 01:34AM
A rapid fire ring shooter mounted on top of a car? (with uber lasers of course) tongue
Mon Apr 12 2010, 04:06AM
Myke wrote ...
It could be the 100W LED...
Electroholic
Mon Apr 12 2010, 07:27AM
Myke wrote ...
looks more like a strobo effect using long exposure time.
how is it related to HV tho?
Tesladownunder
Mon Apr 12 2010, 11:30AM
Or perhaps a flux capacitor rated at 1.21 Jiggawatts.
After this pic, things get interesting. Anyone want to see what happens when I push the red button?
1271071921 10 FT87297 Junkcarroofdaypre600
Wed Apr 14 2010, 04:36PM
how about a giant sized smoke ring generator on top shooting backwards!
Tesladownunder
Wed Apr 14 2010, 07:05PM
Not such a bad idea to have a backwards facing smoke ring machine with the usual red illumination and a strobed tail. My strobe is a 1500W one picked up in a surplus store for $190. It was a hit with the kids on my open day trying to play catch with a strobed ball. Very hard!
However I did post this in the HV section and the capacitor bank next to the car is actually attached. If you look carefully you can just see a fine wire from the top of the upper copper strap to the car roof.
This is an EXPLODING WIRE LIGHTNING SIMULATOR. Ooooohhhh
Lets fire off 5kJ into a 2 foot iron wire in daylight. The iron wire gives the sparkles effect. This is taken with a Nikon D300 with a 2 second exposure backed right off to f22. Cap bank is 220uF charged to 7kV
1271271844 10 FT87297 Junkcarroofday600
The second picture shows the same shot through a neutral density filter - actually some aluminum foil coated plastic used for wrapping flowers over the lens. This shows the central arc channel clearly. Same exposure settings. I have not done current measurements yet but this cap bank has been measured at over 100kA which is the same as lightning current but for a shorter duration.
1271271844 10 FT87297 Junkcarrooffilter600
Now I need to optimise length of the spark channel and make it go to ground over the tyre. I will need to experiment with this. I suspect that adding inductance will lower the peak current (but not total energy). It may be useful to allow the inductive kickback to bridge developing gaps better. Whether this is outweighed by the slower onset of peak current and hence greater wire separation remains to be seen. I have this beaut air cored 10 turn inductor that looks good for 200kA that may be help or maybe the inductance of the longer leads will be enough.
