  • Guests: 32
10/21 ben106 (40)
10/22 803 (2025)
10/23 Iniaes (17)
High voltage mushrooms
Sun Apr 11 2010, 04:56PM Print
haha... now thats what you call science.
We get this over here every time there is a big thunderstorm, next day there are mushrooms sprouting out of grass verges and fields.
-A
Sun Apr 11 2010, 05:06PM
Very interesting; thanks for sharing.
Reporter seems to have a math problem. I think it is impossible for the following sentence to be true, with the conventional interpretation of percentage increases:
"Researchers were able to get the shiitake crop to yield double the amount usually harvested, but the best performing species were nameko mushrooms, which produced a whopping 80 percent more mushrooms."
IntraWinding
Sun Apr 11 2010, 08:26PM
If there really are more mushrooms sprouting after a thunder storm as compared to after just rain then presumably the only differences on the ground that could cause this would be an increased electric field and maybe a trace of nitric acid in the rain?
Alan
Mon Apr 12 2010, 06:27PM
Snowflakes grown in a strong electrostatic field can be induced to crystallize in forms not seen in nature.
Nicko
Mon Apr 12 2010, 06:35PM
I know its not electrostatic, but given a strong enough magnetic field (10 to 16 Teslas in this case), you can diamagnetically levitate a frog (as in the amphibian, before you ask)...
and
Mon Apr 12 2010, 08:48PM
I suppose one should first investigate the circumstances which lead to the fungus 'deciding' to come up at any particular time, and then compare the electrophilic ones with a control group.
While all this is going on, a parallel study of free range hens could lead to some outstanding mushroom omlettes, so the investigation would be a success with or without high potential gradients.
BlakFyre
Tue Apr 13 2010, 06:51AM
BlakFyre Registered Member #1563 Joined: Wed Jun 25 2008, 03:55AM
Klugesmith wrote ...
I too was stuck on this, and had to re-read several times as the only way I can see this being true is if the Nameko value is measured in volume... but even then, everything following it grammatically incorrect. *shrugs*
Anyway, I personally have witnessed some bizarre plant growth in the presence of an electrical storm. I once had a bolt strike right in my front yard, and I swear, right in the same spot grew an unknown species (to me anyway) of flower. At least one that's fairly rare in these parts. Whether or not the lightning storm cause the seed to germinate is beyond saying, but odd none the less.
Tue Apr 13 2010, 06:56AM
ha...
maybe the high voltage did weird things to the DNA by fusing cells from different species?
recall how they cloned Dolly the sheep..
Just my $0.02 worth.
-A
