  • Guests: 55
12/06 Dago (37)
12/06 Z28Fistergod (39)
12/06 JonIverson (45)
Marx Generator Huge sparks (~200.000V)
radhoo
Tue Apr 06 2010, 09:24PM Print
Hi,
See my latest Marx generator (twin variant):
300x110
Construction details here:
Video (in high definition):
quicksilver
Wed Apr 07 2010, 10:16PM
Quality post! It would be great in "Projects" since you obviously put some time and care into it. Which 555 driver schematic did you use?
Thu Apr 08 2010, 11:55AM
nice, pretty spark :D
LutzH
Fri Apr 09 2010, 08:25AM
LutzH Registered Member #1721 Joined: Sat Sept 27 2008, 08:44PM
Thanks for Posting
Simple but elegant construction, with great results. Seeing nice fat Marx bank discharge makes me wonder how it would look if you fed a vacuum tube just like a flash X-ray tube, but with a thin Be window anode, instead of a tungsten target? Would you see a purple flash in the air from the electron beam ionizing it? Sorry to get off on that tangent, but its just been one of those bizarre thoughts which enter my mind when I see a nice Marx setup, good show :)
PS: You must be getting quite a local EMP pulse when it discharges?
radhoo
Fri Apr 09 2010, 08:26PM
Thanks. Maybe a MOD could move it to Projects, I wasn't sure what's the best place to post it myself.
@LutzH The EMP or some spikebacks damaged my lo-voltage powersource feeding the 555 Flyback circuit (a digital voltmeter and the variable voltage block). So it's not that safe yet, must think of some effective protection. Currently I've fixed it and using this version:
@GhostNull: thank you.
@quicksilver: the one posted here: Link2 but with an IRFP460
radhoo
Mon Apr 19 2010, 09:01AM
LutzH wrote ...
Taking a second thought on what you've said above, the similarity between your description and the Lenard window just hit me. See more on:
Mon Apr 19 2010, 01:50PM
Very nice project! Nice output arc.
Just be sure to keep sensitive equipment out of the vicinity when running, and don't run in any room where there could be alarm or heater (digital thermostat) wires running through the room. Unlike Tesla coils which don't radiate much, the discharge from a Marx can induce enormous voltages on any local conductors, especially high impedance cabling and potentially damage lots of things.
radhoo
Mon Apr 19 2010, 05:07PM
@EastVoltResearch thanks for the warnings!
Thu Apr 22 2010, 03:40AM
hey RAdhoo! nice !!! but your low voltage toroidal transformer PS is still vunlerable to overvoltage spikes. and the TIP3055 is the same as the 2N3055, the die are the same but the 2n is a TO-3 case and the TIP is a TO-220 case type. OK they are the same electrically, what would improve your design regardlesss of transsistor choice isthe use of TVS diodes, then youll be bullet proof.
-Patrick
radhoo
Thu Apr 22 2010, 09:16AM
hi Patrick! Thanks for the idea.
I'm already using some neon lamps, that work as a clamping device, suppressing all overvoltages above the breakdown voltage (~90V).
TVS Diodes would be much better (some can handle 1000 - 1500 W of peak power for a short time), I'll see if I can get a few.
How vulnerable is the Marx Generator itself?
