  • Guests: 39
12/06 Dago (37)
12/06 Z28Fistergod (39)
12/06 JonIverson (45)
Linear power supply
Dr. H.
Sun Dec 05 2010, 09:30PM Print
Good day guys
Two of my bench power supplies died almost at the same time and I've finally decided to build a new big one removing the pile of supplies on the workbench.
Sooo after more than a month of work this came to life - a 4 channel 0-20V at 0-4.5A per channel. It has temperature sensors for the heatsinks and the MCU controls the speed of the fan. Each channel has digital volt/amp meter based on pic16f690.
Cheers smile
1291584635 931 FT0 Pic 7217
1291584635 931 FT0 Pic 7219
1291584635 931 FT0 Pic 7220
1291584635 931 FT0 Pic 7222
1291584635 931 FT0 Pic 7228
1291584635 931 FT0 Pic 7236
1291584635 931 FT0 Dsc01609
1291584635 931 FT0 Dsc01611
Sun Dec 05 2010, 10:07PM
Good work! smile
Sun Dec 05 2010, 10:46PM
Really like the setup, would like to see some circuit diagram if you feel like sharing :)
Dr. Drone
Mon Dec 06 2010, 12:49AM
shades
Mon Dec 06 2010, 09:13AM
I could use one like that!
Cheers, Finn Hammer
Mon Dec 06 2010, 07:42PM
I've repaired 'professional' equipment that looks nowhere as good
Realy nice job.
Is it fully operational yet?
P.S. An Earth terminal on the front may be useful.
Dr Hankenstein
Tue Dec 07 2010, 05:30AM
Dr Hankenstein Registered Member #1642 Joined: Sun Aug 17 2008, 11:36PM
You bet it's a nice power supply! Sorry, Finn, It's already been sold to me...I have agents going over to pick it up this weekend! (he, he!) Unfortunately, I kind of doubt that Huben will let it go...
Tue Dec 07 2010, 05:36AM
Daniel Uhrenholt Registered Member #125 Joined: Fri Feb 10 2006, 01:52PM
Nice work Huben.
I could use one myself:)
Cheers, Daniel
Tue Dec 07 2010, 05:51PM
Beautiful..!
Dr. H.
Thu Dec 09 2010, 09:30PM
Good day guys
THANKS for the kind repplys smile
Nope - I am not giving it hee hee tongue
Good day Sulaiman - it is fully operational (atleast for now). There is a small bug with the software of the volt/amp meters but I won't be taking it aparat to fix it (atleast for now). Good catch about the ground connector. I can't believe I forgot it. ... I had to use the handle last night wink
Here is the circuit of the regulator - it is from a local electronics magazine (the v-reg at the top is for the indicator boards). It has 4 identical channels. The volt/amp meters and the temperature monitor are nothing special - based on f690 and lm355.
Cheers
1291930233 931 FT102437 Untitled
