  • Guests: 40
what is a fairly realistic model for a MOT in SPICE?
Crunchy Frog
Tue Apr 06 2010, 02:02AM Print
Crunchy Frog Registered Member #2422 Joined: Tue Oct 06 2009, 02:41AM
What sort numbers do I need to get a reasonable model of a standard MOT (no shunts) in a simulator?
I've been using the "coupled inductor transformer" with 53.8mh pri, 17.65h sec, k=.99 and a 5 ohm resistor in series with the primary, but this seems to draw unrealistic currents (8A) with an open secondary.
I assume someone has at some point needed to simulate one of these things and still has the data lying around...
(thanks in advance btw)
Antonio
Tue Apr 06 2010, 05:34PM
I don't have a MOT here to test, but this model seems reasonable. Maybe with smaller coupling. It is a transformer, and this model is the model of a linear transformer. The inductance ratio and values seems to be in the correct range. The primary resistance is too high.
Tue Apr 06 2010, 06:32PM
Check out Terry Fritz's papers on NSTs at Link2 Although not MOTs, they may help with your model.
radiotech
Tue Apr 06 2010, 08:14PM
Using your model, what is the wattage of the transformer with the open secondary ?.
If the transformer had 53.8 mHy in series with 5 ohms, the load at 120V60Hz would be 5+j20 ohms;, for all intents just inductive, and it would draw about 6 amps and dissipate 180 watts Cu.
It the secondary is open, it might as well be not there.
So likely your numbers are reasonable .
Crunchy Frog
Tue Apr 06 2010, 09:26PM
Ok, thanks.
Tue Apr 06 2010, 09:46PM
8 A input current with no load is not a crazy value -- I have measured over 6 amps in one 120V MOT.
(Are you talking about a 120V or 230V MOT?).
But 5 ohms in series with primary is not a realistic way to model the current limiting effect.
In service, with more than 12 amperes of primary current, most of the input power would be lost there.
Much more realistic, in a simple linear model, is to set primary and secondary series R's
to match the measured DC resistances - probably less than 1 ohm on primary.
Then dial down the k factor substantially, to the point where with secondary shorted,
primary current is around 30 A and secondary current perhaps 1.5 A.
With k much less than unity, you are modeling the deliberate
leakage inductance created by the magnetic shunts.
Read the hvwiki about MOT's: Link2
