  • Guests: 49
01/18 Noelle (43)
01/18 King_of_Junk (36)
01/18 Ixz (35)
Potato Cannon Ignitor
cduma
Wed Feb 03 2010, 10:09PM Print
I am looking for a quick and dirty way to ignite a potato cannon from a distance without a complicated reload or a 110VAC source.
My idea was to convert 9VDC to 110VAC by attaching one terminal to a 110:9 transformer and the other to the end of a stranded wire and brush it against a file. This should give some really poor quality AC but, it should be good enough to drive a 2KV MOT and produce an arc.
I must have a cheap and reliable way to remotly ignite mostly for my own safety since I undoubtedly will try stupid dangerous fuels eventually.
Wed Feb 03 2010, 10:45PM
What i would suggest is taking a magneto from an old lawn mower, weed wacker, or other small engine. You can wind a primary on a random part of the iron core, maybe about 10 turns or 20 gauge, and discharge a capacitor into it. The capacitor size does not really matter too much. I did this once, with a capacitor charged to maybe 24v and around 100uf, and i got a spark like 3/4 inch long. I used that for my spud cannon. You could use a few series 9v batteries. The higher the voltage, the better.
If you can, just use some high voltage wire, or some wire that is far from anything it could arc from, and use a piezoelectric BBQ ignitor. You can run a couple wires out wherever, and you have virtually unlimited ignitions without needing a power supply. And, it is small and reliable. cheesey
Good luck, and be careful!
Aussienitro
Thu Feb 04 2010, 02:49AM
Aussienitro Registered Member #2399 Joined: Mon Sept 28 2009, 09:29AM
Hmm you could just buy Link2 for $6.50. Just connect a 12v battery a spark plug and a switch and you should be good to go.
teravolt
Thu Feb 04 2010, 04:56AM
put a spark plug in your canon and use a standard ignition coil and use a 2n3055 ignition ciol circuit with a 12v motercycle battery
Thu Feb 04 2010, 10:37PM
-camera flash charger with a smaller cap +spark gap to discharge into a pulse transformer/ ignition coil or even a flyback
-small DST flyback driver
-piezo igniter (I have run these attached to a few meters of wire and seemed to work ok)
cduma
Thu Feb 04 2010, 10:40PM
I will probably go with the lawnmower ignition coil method since the shipping is too high for me.
Thu Feb 04 2010, 10:50PM
cduma wrote ...
Well, you can get the BBQ ignitor from hardware stores. Or, at least you can down here.
cduma
Thu Feb 04 2010, 11:10PM
They are rather expensive though. I would pay the $6.50+$7sh first since they are about $12
cduma
Thu Feb 04 2010, 11:59PM
Last time I couldnt solder it right
DrZoidberg
Sun Feb 14 2010, 12:41PM
DrZoidberg Registered Member #350 Joined: Mon Mar 27 2006, 05:14PM
You could also use a small light bulb and break the glass.
