  • Guests: 77
Will these caps work in a Marx Generator?
sparky99
Mon Apr 05 2010, 01:25AM Print
sparky99 Registered Member #1159 Joined: Fri Dec 07 2007, 02:10AM
I have a bunch of metalized polyester film high voltage capacitors. I'm thinking that these might work because of the low rep rate of a Marx generator................what do you think??
Thanks,
Bob
cjk2
Mon Apr 05 2010, 01:37AM
I do not believe there is enough information in your post.
Voltage rating of said caps?
Current rating?
Construction?
Do you have a data sheet?
Pictures?
sparky99
Mon Apr 05 2010, 02:39AM
They are 4700 pf at 50 kv. That's all the info I have.
bob
Mon Apr 05 2010, 10:16AM
They will certainly work in a Marx gen.
The question is - how reliable will they be?
If you have a suitable resistor from the Marx output then I'd say very reliable, if no resistor then they will be as unreliable as any other type of capacitor !
mikeselectricstuff
Mon Apr 05 2010, 09:56PM
Thet is certainly in the right ballpark for value. If you have some spare it would be worth doing a destruction test to see how robust they are - e.g. charge witha 25kv flyback supply and forming a relaxation osc with a spark gap across the cap.
Tue Apr 06 2010, 06:12AM
yeah i agree with said suggeston form "mikeelectricsuff" a destructive test properly done would be good as you do not have a datasheet, which is best.
however, if you are unwilling to destroy one, maybe you be super duper restrictive with power, and repitition rate. ( i.e. use a high resistence to limit current, and a infrequent shot rate. )
-Patrick
mikeselectricstuff
Tue Apr 06 2010, 12:06PM
I woudn't be worried about destroying one - if they aren't up to the job you won't be building a marx with them anyway - the value of the knowledge of what they will & won't take is well worth the cost of a dead one before going to the effort of builldeing a marxgen & then killing the caps because you didn't know how far they could be pushed!
