  • Guests: 78
Use a HOT on ZVS Driver
benproiii
Sun Apr 04 2010, 10:25AM Print
benproiii Registered Member #2703 Joined: Sun Feb 28 2010, 06:02PM
can i use two of the horizontal output transistors from a crt tv in the zvs driver it killed all my fets
Sun Apr 04 2010, 10:48AM
no
Sun Apr 04 2010, 12:14PM
but you could use two HOTs in a push-pull driver-oscillator
Antonio
Sun Apr 04 2010, 01:24PM
They are not FETS, and the driving mode is different. They are also designed for high voltage and not so high current. The zvs driver can easily stop oscillating, and when this happens it draws a huge current from the power supply and self-destructs. The ideal solution would be to add a circuit to shut down the power supply, or both transistors, (fast!) if the current exceeds a certain limit.
Sun Apr 04 2010, 06:07PM
Google search current fed Royer oscillator.
