  • Guests: 31
10/21 ben106 (40)
10/22 803 (2025)
10/23 Iniaes (17)
Is microwave turntable motor reeally a synchronous motor?
cavemen
Sat Apr 03 2010, 03:56AM Print
cavemen Registered Member #2008 Joined: Tue Mar 03 2009, 05:11AM
I am trying to build a machine that would require two synchronous motors that can maintain the timing.
I was looking for a light-duty synchronous motor and I see a lot of microwave turntable motors being sold as synchronous.
I had one in my house and I ripped it apart to see what is inside. There are layers of stamped plates with gears and there is a motor. A small ring-shaped winding stator and a thyroidal magnet for a rotor. I need that part.
Before I buy two identical motors of this kind, I want to make sure those are really
synchronous. Would those motors loose their synchronization if I run them without a load of the reducer mechanism that I pull out of the case?
I will probably find some way to machine moving parts for those motors. So I will just use the winding and the round magnet, since those motors will be used for higher duty application.
Thank you.
Sat Apr 03 2010, 05:54AM
If the rotor is a permanent magnet then it's a synchronous motor,
it will be synchronous with or without gears, with no-load to full-load.
Sat Apr 03 2010, 06:19AM
If this does not work out for some reason, you can always go for a dryer or washer timing motor i am sure.
But i am fairly sure MO's use sync motors. I remember i used to have one that i turned by hand and it would zap you a little bit because of the induced voltage. Things where simpler back then smile If the motor is not syncing then you will hear it. The sound will change, you will know it when you hear it.
And again, if that does not work because you need more torque, you can make a MO fan motor into a 3600rpm sync motor, by sanding two flats 180 degrees from each other (or 4 flats 90 degrees from each other for a 1800rpm motor). You just shave it off until it starts running sync. I made a srsg that way once.
Sun Apr 04 2010, 12:50AM
In my experience most MWO turntable motors are true permanent magnet synchronous motors. The rotor turns once every 4 to 8 cycles of the AC power.
This is geared down to, usually, an integer (like 4) revolutions per minute.
So if you run the MWO for a whole number of minutes, the turntable stops in the same orientation as it started (e.g. with coffee mug handle facing the operator's favored hand).
Often they save a penny by omitting the anti-reverse pawl, and of course they would never dream of including a capacitor or pole-shading loops. So the direction of rotation is randomly chosen each time the motor starts.
Back to original question: I think there isn't much you can do to greatly increase the torque of the rotor. (just cheap ferrite or plastic permanent magnet material). You can determine the number of pole pairs by inspection of the stator.
cavemen
Sat Apr 10 2010, 11:19PM
Thank you for telling me a lot of useful information.
Do they make small motors with two poles that make 1 revolution/ AC cycle?
Can i convert a microwave motor into one?
What is under that single coil of wire that surrounds the rotor, that defines what is an rpm/ac cycle ratio?
I need 1rpm/cylcle, because i want my motor to speed up on one half of the way and slow down on the other, but that is a long story of what the mechanism does and how it overcomes inertia of the rotor.
I just want the power to pulse, so one half of the wave would go through a resistor and diode, the other one will go straight.
radiotech
Sun Apr 11 2010, 01:27AM
Look into a type of AC stepper motor called a SLOSYN- High Torque, Slow speed. They were available cheaply as surplus.
Sun Apr 11 2010, 02:15AM
If you need a synchronous motor you can find them on Ebay. I have one for my TC.
cavemen
Sun Apr 11 2010, 03:16AM
i mean that my moter needs to accel for the half of the revolution, decel on another half
radiotech
Sun Apr 11 2010, 04:11AM
To do this on 1 AC cycle, you could look for a 'syncronous' chopper.
It vibrates at whatever coil frequency is specified and has a switch contact that moves from one contact to the other at syncronous speed. They are sealed, and plug in.
Here is An OAK chopper
1270959110 2463 FT86764 Oakchopper
Sun Apr 11 2010, 03:12PM
If you have a fixed frequency drive you can't slow down the motor for 1/2 cycle by reducing voltage/current/power etc. it's a SYNCHRONOUS motor!
What's the application?
