  • Guests: 52
HV supply test
dmg
Thu Apr 01 2010, 04:56PM Print
a "test" of an HV supply I made, using the most sophisticated method of HV testing.... chicken sticks.
our subjects to abuse... err. I mean testing are a motor's armature and some random bolts and plates.
the output is about 6KV at 1A shorted, under load I figure it gives out around 600-800ma.
power factor corrected and only draws 12A or so, can be run off regular 120V mains.
the thing barely heats up in the air, let alone under a bath of oil.
nothing really here other then arc pictures I thought are worth sharing.
I also managed to get a lucky shot of the arc just as it was extinguishing.
perhaps a future spark gapped TC supply?
1270140975 2628 FT0 Akilla2mr 001
1270140975 2628 FT0 Arcer 002
1270140975 2628 FT0 Arcer 010
1270140975 2628 FT0 Arcer 030
1270140975 2628 FT0 Arcer 031
Alexandre
Fri Apr 02 2010, 01:09AM
Alexandre Registered Member #1228 Joined: Tue Jan 15 2008, 01:08AM
Actually the values of voltage and current can apparently be used in a Tesla coil .. shades
I used a power supply in lower values than this that you submitted, which was two MOT's in the series, giving here aproximandamente 4.3kV @ 450mA, and got something around 60cm sparks ...
Alexandre
Matt Edwards
Sun May 09 2010, 04:34PM
Matt Edwards Registered Member #2838 Joined: Fri Apr 30 2010, 07:55PM
Be careful! One wrong move and your not getting up! Anyway, Search you-tube for mot Tesla and you will find a few good ones. I made a simple Jacobs ladder. Could never get it to start on its own unfortunately but it was still impressive to watch. (It was my first HV project...) Link2
