  • Guests: 40
williamn (48)
ReddyK (57)
Birdman (31)
12/14 M.A.D. (32)
12/15 marko666 (58)
12/16 Will T (16)
Cheap high altitude photography.
Coronafix
Sun Mar 28 2010, 05:19AM Print
How easy is this!!
Sun Mar 28 2010, 06:01AM
Cool! The same story was reported in the local paper here in California.
Here is a similar project with similar technology:
But let's put this in perspective, when casually using the word Space, and comparing the cost of weather balloons with satellite technology.
These amateur balloon-cam pictures show a relatively dark sky and curved horizon (using wide-angle lens) from 20 or 30 km up. Reconnaissance airplanes have cruised that high. Re-entering satellites burn up at air densities 100x or 1000x lower.
To win the $10M Ansari X Prize, a one-man rocket twice coasted up to an altitude above 100 km. THAT could fairly be called "space" -- [edit] but the air is still too thick for a satellite to orbit the earth.
But reaching low-Earth orbital velocity requires 25 times as much energy per kg
as merely climbing to 100 km altitude.
Sun Mar 28 2010, 06:30AM
klugesmith i am intrigued by your math can you explain briefly or include links to the math that descibes the kinetic energy reqiured at different alts like what Rutan achieved versus a satilite? plz ty,.
-Patrick
Sun Mar 28 2010, 06:46AM
Patrick wrote ...
-Patrick
simple.
Sitting still at 100 km, about to fall back into the atmosphere, your potential energy is m * g * h -- about 1 megajoule per kilogram.
The record altitude for a shell fired from a gun on the ground is 180 km (HARP / Gerry Bull).
Flying at 7800 meters per second, your kinetic energy is m * v^2 / 2 -- about 30 megajoules per kg. And you really should be at least 200 km above the ground, so there's another 2 MJ/kg.
[edit] I just figured the orbital energy of International Space Station to be about 1.14e13 joules (2.7 "kilotons"). Given the inefficiency of multi-stage rockets, the energy of rocket fuel burned to put it there must have been triple-digit kilotons.
Coronafix
Sun Mar 28 2010, 07:02AM
By no means is it "space" photography, but it does get it high enough to get the same feel from the photos.
Tracking it would be a lot harder if you could get it up into low earth orbit, not to mention the fact that it would need heat shielding to come back down.
This technology alone would need a specific weather to launch it so that you don't have to drive a thousand kms to retrieve it.
Sun Mar 28 2010, 07:04AM
whoa! crap ur right i need to look at my physics text book again, energy is relative to your position in a gravity field is what you describe.
wylie
Mon Mar 29 2010, 02:18AM
wylie Registered Member #882 Joined: Sat Jul 07 2007, 04:32AM
All i know is, thanks to that link we have probably less than a year until someone on this board uses a disc launcher to send up a camera.
I can't wait smile
EDIT: or a rail/gauss gun maybe.
RE-EDIT: just splitting hairs i guess. a linear accelerator by any other name would smell as sweet, and all that jazz.
