  • Guests: 20
EEYORE (42)
TeslaJunky (32)
07/16 Gavin (49)
07/16 Froskoy (33)
07/16 UnHappy1 (59)
Waterless sterilizer "washes" hands with room temperature plasma
IntraWinding
Sat Mar 27 2010, 09:59PM Print
I Stumbled on this: Link2
radiotech
Sun Mar 28 2010, 02:56PM
How does this work? Is it ozone from spark or heat? Small germicidal lamps are used to sterilize by hard UV but they will burn skin quickly.
brtaman
Sun Mar 28 2010, 04:35PM
brtaman Registered Member #2161 Joined: Fri Jun 05 2009, 03:36PM
From what I see in the article, it is the same principle as the plasma pencil without the need for a gas source. HV is pulsed with short nano-second pulses at relatively high frequency, into 2 discs in a tube both separated by a dielectric, with a single or multiple holes, this prevents arc formation and results in a cold jet of plasma out of the output nozzle. The resulting cold plasma is kills of bacteria.
I imagine this works on the same principle with a different electrode shape/arrangement.
Best Regards,
brtaman
