  • Guests: 26
10/21 ben106 (40)
10/22 803 (2025)
10/23 Iniaes (17)
alternative to c5720 transistor
audio:deviant
Thu Mar 25 2010, 06:50PM Print
audio:deviant Registered Member #2081 Joined: Wed Apr 15 2009, 11:36AM
hello all,
i wouldnt normally ask about something like this but im having no luck what so ever trying to find an alternative, it came out of a camera flash board im not sure if that helps. have had no luck in the local 'lecy shops
cheers in advance,
james
Thu Mar 25 2010, 06:59PM
It's a 2SC5720... Japanese transistor part numbers always begin with "2S" but they leave it off the package to save space.
It's actually quite a powerful transistor. Maplin have the BD237, different package and pinout but it might do.
audio:deviant
Mon Mar 29 2010, 04:07PM
thanks steve! ill see if i can get some samples from rs. i ment to put in the serial of a couple that came out of them,
D965
C5720
dont know if that help at all.
Mon Mar 29 2010, 04:15PM
Well, I guess the "D965" would be a 2SD965 Link2
5 amp current rating, and gain of >150 at 2 amps, that'll be a tricky one to substitute. There might be something in the ZTX series from Zetex.
