  • Guests: 26
seveerz (69)
10/21 ben106 (40)
10/22 803 (2025)
10/23 Iniaes (17)
tying a +15v and -15v supply
Sun Mar 21 2010, 03:48AM Print
I took a center-tapped transformer and connected each half to its own rectifier/capacitor. My plan was to connect the negative side of one to the positive side of the other for a common lead. This way I would have +15v and -15v with respect to the common. However, current flows between the two.
Do I need to connect the common to the center tap?
1269143309 190 FT0 Circuit
Sorry for the double post, but is this my only solution using single diodes using this type of topology? I am not looking for solutions using 555 timers or other devices.
1269143840 190 FT86112 Circuit
[Edit: Oh no, now we know that you knowingly double posted out of pure malice!]
MinorityCarrier
Sun Mar 21 2010, 06:44AM
Just have a full wave bridge across the outer 2ndry xfmr windings and use the center tap as common return. What you have in your second diagram will have 60 Hz ripple.
Sun Mar 21 2010, 10:40AM
Yes, what MinorityCarrier says is the industry standard way of doing it. Half of the diodes in your first circuit are doing nothing.
ScotchTapeLord
Sun Mar 21 2010, 02:16PM
You don't even need a center tapped transformer necessarily, since the capacitors should ideally split the voltage themselves, but if you have one then you might as well use it. When I made this circuit it was just transformer -> rectifier -> capacitive divider + balancing resistors.
radiotech
Sun Mar 21 2010, 06:06PM
For 60 years the full wave, center tap transformer, rectifier was used.
Any half wave rectifier connected to a transformer has a problem with wasted metal in the winding. For a given regulation the wire size has to be bigger because the winding has only 1/2 cycle to furnish
the power needed by the load. It idles and takes up coil area half the time. That factor means bigger cores with their losses. And worse, in the half wave rectifier it throws a 2f back on the line.
scan is Ghirardi, A Radio Physics Course 2nd. Ed Murray Hill Books New York 1932. (great book to learn how to read with; electronics can be learned later)
1269194787 2463 FT86112 Scan0010
Sun Mar 21 2010, 10:07PM
You do need the center tap, in case you draw slightly different currents from the + and - rails.
Look at the "split rail" schematic on the last page of this PDF to see how it's done.
Radiotech, what is this old vacuum tube stuff? tongue
The split rail power supply is just two "full wave center tap" rectifiers, as you call them, one providing a positive supply, and the other with its diodes turned backwards to provide a negative supply.
radiotech
Mon Mar 22 2010, 03:08PM
Vacuum tubes are just a passing fad likely to be replaced and should not bother much.
Mon Mar 22 2010, 03:30PM
Tell me about it... Link2
(I'm working on a fourth one)
BTW, I heard that the 6L6 tube is the longest running electronic component ever?! It was introduced in 1936 and is still being made today.
radiotech
Mon Mar 22 2010, 09:48PM
"BTW, I heard that the 6L6 tube is the longest running electronic component ever?!"
That could be true. The metal ones came first I think.
I believe the sound from a metal one is purer.
1269294522 2463 FT86112 6l6
