  • Guests: 40
seveerz (69)
10/21 ben106 (40)
10/22 803 (2025)
10/23 Iniaes (17)
IGBT repair using homemade wirebonder?
Sat Mar 20 2010, 08:54PM Print
hmm... maybe those fried IGBTs (or defective new ones) can be repaired or at least patched up by cutting out the blown sections? (most are several identical IGBTs on the same substrate with separate wire bonds)
ideas:- modified PS3 laser module stepper motors as these have 5mm throw at ridiculous levels of precision
what would also work is three laser positioner units from old CDROM drives, x/y/z for not much money.
-A
"Bother" said Pooh, as the aliens invaded...
Sun Mar 21 2010, 02:53AM
"Bother", said Pooh, as Andre killed his last SOT-227 40n60 while 'fixing it'...
If you could somehow do this, i would be incredibly impressed.
Sun Mar 21 2010, 03:12AM
All of the failed to-247 type transistors I have used have had the whole die vaporize (I am sure you have seen the pictures of what a IGBT looks like after a bad failure). In the large 'brick' type dies it is probably quite possible to just use a tweezers to remove the wirebonds to a fried die, but all of the damaged bricks I have come across had all of the dies vaporized so it wouldn't help much in any case. The diodes still work great though!
Sun Mar 21 2010, 10:42AM
OK, bond this :P
Igbt Explosion 2
hboy007
Mon Mar 22 2010, 10:01PM
Nice one, Steve!
I'd like to see someone cut out parts of a power semiconductor but even more tempting will be to buy LEDs as cut wafers on blue tape and assemble higher density LED displays on glass.
I don't trust resistive heating and spark preconditioning of the bonding wire very much when it comes to homebrew solutions. However, I can imagine a solid state laser performing the actual heating.
Tue Mar 23 2010, 07:55PM
yep that would work.
otoh, i did wonder about using old ITO glass from a defunct touchscreen (I have two) and then etching it into strips.
Put LEDs between two sheets of glass and voila!
(a single piece of copper clad could replace one of the ITO layers)
Another idea is to use self assembly. put tiny drops of solder paste onto the pads then heat up the substrate to 150C or so and solder the assembly in one go with heat from above.
The best bet for this would be GaN on SiC based LED chips as they have top and bottom contacts.
-A
mikeselectricstuff
Wed Mar 24 2010, 12:07AM
Problem with LEDs and ITO is that readily available ITO (LCDs, touchscreens, heated freezer cabinet door glass) is too resistive. While it can and has been done, it needs a rather thick coating to get the resistivity down. Patterened ITO thick enough for LEDs is fairly visible
Nicko
Fri Mar 26 2010, 04:20PM
Just seen this:
The guy that runs the group has this down to fine art - its a very very skilled job!
