  • Guests: 25
seveerz (69)
10/21 ben106 (40)
10/22 803 (2025)
10/23 Iniaes (17)
kool educational java applet simulators
teravolt
Fri Mar 19 2010, 04:35AM Print
I found this kool website for doing simulations. One of the applets has a visual way of seeing electroncs. you can add parts or scope channels to the simulation to change the outcome. They even have a class d amp if anybody want to see how they work. just select a circut and run your curser over circuit and see current and voltages and do a right click for the menue. you can add parts and wires move parts and wires. Anybody who knows spice wont have any problems.
Link2 and the main page
Myke
Fri Mar 19 2010, 05:11AM
I love this app. I think it's a great learning/teaching tool.
I found this page a while ago and it has been posted here under "Java applications": Link2
Renesis
Fri Mar 19 2010, 08:52AM
Renesis Registered Member #2028 Joined: Mon Mar 16 2009, 08:13PM
Yeah, Falstads circuit simulator is really great, i use it a lot. They have recently updated the simulator too, with amongst others a simulated spark gap.
The nicest feature is that the simulation is dynamic, you can see what's going on and even alter your circuits while the simulator is running.
There are some disadvantaes though. When you reach into the >100kHz range it becomes impossible to retrieve any useful data because the scope function is too slow. Also, being a java app it is very slow and large simulations require a lot of processor power. And you cannot zoom, so the circuit size you can simulate is very limited unless you have a high screen resolution.
Myke
Fri Mar 19 2010, 06:37PM
You can change the simulation step time to view things into the GHz range. smile
I agree that it's a bit limited but it definitely is still useful for many simple simulations.
teravolt
Fri Mar 19 2010, 07:31PM
thanks for the other links Myke, since Steve daybued
his new coil I have been tying to find out what he did and have been studing different class D amplifiers and stumbled on Falstads. I Wonder if there is a feture for stating a simulation from scratch. I have been able to add components to change the simulation.
Fri Mar 19 2010, 09:16PM
teravolt wrote ...
...One of the applets has a visual way of seeing electronics.
Very nice indeed - I've seen it before.
Two things to keep in mind, regarding his illustration of electrical current by moving dots on the wire.
1) The dots move in the direction of conventional current, as if they were little -positive- charge carriers.
That's fine with me. I think that beginners should start with conventional current. Practical batteries, lights, even commercial 3-phase AC power grids and utility tariffs were in place before the discovery of the electron (which turned out to have a negative charge).
2) The distance that the dots move is greatly exaggerated for clarity. In the opening example simulation (41 Hz damped oscillation starting at 50 mA), the peak-to-peak displacement of electrons in an AWG30 wire (D=0.25 mm) would be only 600 nanometers -- one wavelength of visible light.
Hazmatt_(The Underdog)
Sat Mar 20 2010, 03:13AM
I think its amazing work. Kudos to the author.
