  • Guests: 57
10/21 ben106 (40)
10/22 803 (2025)
10/23 Iniaes (17)
FULL BRIDGE PCB....Wanna take a look?
EEYORE
Sat Mar 06 2010, 09:19PM Print
Hello all,
I am planning a full bridge for tesla coiling. I figured I would have it made via expresspcb. Anyone care to look at my design and give me your thoughts?
Here is a screen shot...
Thanks,
Matt
1267910350 99 FT0 Full Bridge
cjk2
Sun Mar 07 2010, 06:30AM
It's hard to tell what is really going on. As far as trace size it looks good. I would stay away from the SMD stuff on a board like this. It is just harder to work with and possibly less robust, harder to replace, etc.
You might also consider using a real PCB fab house. Im not sure what you will pay at pcbexpress, but I know that gold phoenix will do a whole 100 sq inch panel for about $100 shipped.
EEYORE
Mon Mar 08 2010, 03:26AM
cjk2 wrote ...
Hello,
Expresspcb is a bit more expensive than others, but they are very easy to use and their software is extremely easy to use. I have used them for a lot of things and always happy...
The basically has two GDTs in the middle in parallel with each other and four to-247 devices forming the full bridge. (Actually I plan to use three terminal screw connectors for quick part replacement).
I chose to go SMD on the back to back zeners and gate (or base) resistors since I never have had them fail before. I am also pretty good with SMD (super steady hand). smile
Matt
